Went to change a broken clutch cable, discovered car has cancer, bit emotional at this moment. Knew it was coming, didn't expect the scope |
davebrossi |
Sep 8 2018, 04:39 PM
Member Group: Members Posts: 52 Joined: 6-December 11 From: Idaho Falls, Idaho Member No.: 13,868 Region Association: None |
Hi All,
I prefer most often to lurk, but after a spin to a nearby autobody shop about filling in some rock chips on the rear fender flairs of the clown car netted me a 13,500 estimate, I've been a little on edge for rust. This morning I set out to change the clutch cable which had snapped last weekend. As I was getting myself situated I noticed some of the undercoating seemed more...flaky than usual. I moved my finger towards it, brushed it and off it came! along with another small piece. I was now staring in disbelief at a mixture of pink body filler and carpet. OK! I told myself, this seems relatively minor, let's just clean the area, I can fix this, maybe not the best way, but I can!. That was five hours ago. As I worked I realized I needed to see where the damage was on the interior, so I removed the carpeting. Once again, I spied a familiar orange tinge... under the urethane installed at the factory. I started working with a chisel and hammer. What was a small hole was in fact a seam running along and right up to the driver's side right seat bracket. The concrete below glared at me menacingly. The clown car (my 914-6) was the result of an venture from a forum member offering turnkey restoration of 914s. I have no interest in flaming or anything mean, so I will not say who, and that's not a challenge either, since frankly all of this was beneath urethane, and said individual cleaned, primered and properly painted surfaces all the way to the old urethane on the floor pans. but it is worth mentioning because rather than spiral down the inception styled road of 'oh god I'm doomed, DOOOOOMMMMED!' I sat back and thought about what they -had- restored and what I had to go back and work on. The interior of the door panels was rusty, I sanded, sealed with POR15, clear coat has a craze to it, but stable and looks fine. Small side sail bumps. Originally thought body filler, probably tin worm, but unlikely to fail while driving and drag me half out of the bottom of the car. Longitudinals, hell hole both extensively reviewed during restoration, both are clear. I don't see bubbles all over the car, and the 13500 was with a note saying "we don't serve yer kind round these parts try these guys since they do antiques" from a shop filled with classic american muscle cars and more of a 'get lost' message, which I understand because scope creep is real. I want to believe this is one of those typical stories where I don't wind up with the Porsche 914 equivalent of "you have died of dysentery" on the Oregon Trail PC game, but I also have to face up to the fact that I will have to acquire new front and rear floor pans. Happily they can be ordered from Pelican without much fuss (the available weld in panels for the 914 is really REALLY a reason I love them in an odd sort of way.) I know I have to invest in a welder as I lack the skills. I want to prepare the area as best as humanly possible because A.) I believe in being a good steward and B.) I'm afraid while I'm happy to pay for their services, I am cheap and would prefer to do the prep work myself. Advice (maybe prayers?) is/are appreciated, but I will be searching threads and educating myself accordingly as I know I need to. in the meantime, here's some NSFW Porsche Floor pan gore; the initial discovery and early cleaning The point at which I realize I should probably look at the top end of things. because regrettably I am a millenial, I wanted to show off my PPE for working with fiberglass and sanding. The moment my heart sank, the colour drained out of my face, and I had to go have a little sit down. (IMG:style_emoticons/default/barf.gif) This is the extent of the rot. You can see the garage floor clearly a menacing glare fixed on it's eyeball-less face :E! I wont blame the consumption of Hubert's lemonade, wait, no, yes I'll blame it for the rust after all! The start of (and at which point I realized that the floor pans were toast on both sides) the surface rust on the other side. I'll admit it was heartbreaking to discover. I wanted to give up and throw it all away, sell it and be done with it. But then again, new front and rear floor panels are made for a reason, and the last undiscovered country (Star Trek) both my father and I were starting into was body work in the last couple years. I'm hoping I'm not right thinking this will require the selling of one of both a kidney and a lung, frankly I have no idea, though (in a phrase I use talking with my employers often) I look forward to the opportunities it will afford me moving forward. Bonus points here in how my dad managed to cause the usual reaction that always happened when there was a setback and he had to tell mom one last time. (IMG:style_emoticons/default/chair.gif) |
davebrossi |
Sep 15 2018, 12:07 PM
Another weekend, and another discovery (IMG:style_emoticons/default/barf.gif) but first, some context as to what I went about doing today. owing to the discovery I made regarding rust's preference to be lazy and go for the lowest points in the pans, and the fact that I burn through three cordless drill batteries in under two hours, I have to be picky about where I chase bare steel. So I started by going down the upper and lower pan on the driver's side from under the car, checking the depressed areas. Sadly there is no SSRI to provide them with a shinier rust free outlook, but no additional pinprick sized holes reared their ugly heads
I turned my attention briefly to the Passenger's side where the Motronic brain of my 3.2 was.. so very sophisticatedly mounted to the chassis. No, really, The bolts have in-tact sealant around them, though the hole in the middle defeats the purpose :-) There has been -genuine- concern about the state of the longitudinals on the car, and I know there was also concern when I mentioned a body strengthening kit had been added. A cursory look at the longitudinals showed black tar, save what looked like what -might- be slight bit of rust down by the front driver's side jack point. It was then I noticed 'well, um.. that metal that makes up the back side of the front trunk looks the wrong colour. (IMG:style_emoticons/default/hissyfit.gif) I don't have a picture of the trunk metal, but it is -surface- rust so I know with some effort and no welding, I'll be OK. The usual 'boy it's a good thing you brought it to us, because this, this, and this was also wrong, but we done gone fixed it fer ye!' situation (IMG:style_emoticons/default/chair.gif) This is the best I could provide of a longitudinal au-natural, I was quickly running out of voltage, but along the driver's side, nothing making me wish I went into coin collecting instead This warrants further exploring during the process, but I fear both creeper and myself are too fat to get that far forward for me to attack with my spinning harbor freight wheel of death. at this point, not seeing anything on the passenger's side yet under the car to cause concern, I remembered 'wait, you had what resembled Nietzsche's void on the passenger's side just behind the ECU. So I decided It was time to try and explore the Event Horizo....er, I mean passenger's upper floor pan. CAN YOU SEEEEEEEEEE!!??? (last of the Event Horizon jokes..I think?) I carefully unbolted the ECU and wiring, moved it out of the way, removed the seat belt bolt and carpeting. Then it was time to get to work. I think it worth pointing out that under the ECU the Floor pan was perfect, like depressingly exactly what a healthy piece of metal should look like. For the most part I'm seeing mild surface rust, but rust none the less that gets exceedingly worse looking until the firewall....And that's when I saw -it- I know everything can be patched, but my hope (stupid as it is) -had- been to get the car prepped, temporarily get a seat in the driver's side and drive it to a place with a lift to help the welder out. What I see here instead is the lower firewall on the passenger's side has not fared well at all. One could surmise that if time is the fire in which we burn, this wall has fared about as well as Pink's in the Seminal "the Wall' Album (At least I've been comfortably numb about all this today! yay Pink Floyd!) They say cars can sometimes talk to you. I was talking back in this one... Here is the sign of the beast close up. I'm new to the concept of 'welding in chunks' so I'm hoping someone might chime in with "Dave you don't have to drop the motor and transaxle, but you'll have to be very careful to weld in a new panel." but what I'm expecting is 'nope, lolz, better get some more of those wood shims to prop the floor jacks on so the motor can clear the car!'....I know it's 'easy' to drop the motor, but, again, scope creep. I switched tactics at this point and went back to 'chisel and beat the ever loving shit out of the urethane until it flies up at me' tactic to clear up more of the metal. Below is the length of the floor pan as it joins up to the center support post. Note the 'gentle singularity' in the right hand side of the photo Sadly there's no time dilation effect or red shift, just the red mist descending... see what I did there... slowly? (IMG:style_emoticons/default/headbang.gif) I wanted again to contrast where the ECU was mounted and what I am led to believe a healthy floorpan looks like. Switching back and forth on the type of wire brush I was using I wanted to now dig into the area around the chassis/frame and where it meets up with the floor pan. At the very edge you can see distortion that I'm going to classify as rust meaning the tip of the pan at least is in a bad way. That said, the area around the seat mounts doesn't show any signs of concrete garage floor and the slip'n'slide adventure I would have encountered one day (probably in a tight turn at speed, let's be honest) but I'm not quite feeling 'nope, we'll be good' just yet. I noticed some creases in the urethane coating just forward of the cross sectional bar. I didn't get a chance to crack into. Foregoing another heady picture of Gargantua there in the firewall, here's what the back corner of the passenger's side looks. The optimistic part of me goes "yessss, it's time for pizza....It also then notes that again the damage appears localized to the upper floor pan. By this point I was about at the end of my third battery pack and so I had to... -pack- it in. (IMG:style_emoticons/default/chair.gif) One final shot of the corner before I go though; My neighbors did cheerily wave before leaving apparently having come to see me dressing up as a space man as normal for a weekend. So there is that. Attached image(s) |
Lo-Fi Version | Time is now: 11th May 2024 - 05:26 PM |
