TC's back in a Porsche......kinda! |
carr914 |
Sep 9 2018, 06:56 AM
Racer from Birth Group: Members Posts: 118,490 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
my two year experiment with building a LS3 73 Camaro is over! Couldn't get a shop to finish some things (and it wouldn't fit in my Garage).
I'm a Driver 1st & foremost, so it has been a grind to see a project going nowhere, so my latest pickup is with LS6 Motor! (IMG:style_emoticons/default/piratenanner.gif) |
Rob-O |
Sep 20 2018, 06:34 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Just a quick question about the wheels on this thing. They look like (and I’m pretty sure are) 17” Boxster rims. I assume 7” and 8” wide but do you happen to know the offset? Curious what size tires those are, too. I just picked up a rough 944 Turbo and I like the look with those wheels. I looked up companies that do LS conversions and one of the first places that popped up on my internet search was a place in the same town as me. Had no idea these guys even existed but plan to run by and check out their operation soon. 944 Turbos came with "early" offset wheels (1986) and late offset wheels (87-89). The "twist" wheels came in 7/8.5 widths on the boxster and 7/9 on the 996. These are late offset wheels. Typical late offset are ET50-60mm.. Early offsets are ET10-23. Great information, thanks. Just trying to wrap my head around this. I have an ‘86 so early offset. Since the offset is the spacing on the inside of the rim that would mean if I want to use later wheels I’d need spaces (roughly an inch in this case) and possibly longer studs? I’m I thinking that through correctly? |
Racer |
Sep 20 2018, 11:03 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Just trying to wrap my head around this. I have an ‘86 so early offset. Since the offset is the spacing on the inside of the rim that would mean if I want to use later wheels I’d need spaces (roughly an inch in this case) and possibly longer studs? I’m I thinking that through correctly? Correct... the '86 944T (951) ran early offset 7/8 x 16 wheels (Fuchs and Phone Dials) with an ET of 23.3mm front and rear. To run "late" offsets, you would need about 28 mm of spacers. 1" = 25.4mm so, 1-1.25" could work. |
Lo-Fi Version | Time is now: 9th May 2024 - 04:42 PM |
