TC's back in a Porsche......kinda! |
carr914 |
Sep 9 2018, 06:56 AM
Racer from Birth Group: Members Posts: 118,490 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
my two year experiment with building a LS3 73 Camaro is over! Couldn't get a shop to finish some things (and it wouldn't fit in my Garage).
I'm a Driver 1st & foremost, so it has been a grind to see a project going nowhere, so my latest pickup is with LS6 Motor! (IMG:style_emoticons/default/piratenanner.gif) |
Rob-O |
Sep 20 2018, 02:51 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Just trying to wrap my head around this. I have an ‘86 so early offset. Since the offset is the spacing on the inside of the rim that would mean if I want to use later wheels I’d need spaces (roughly an inch in this case) and possibly longer studs? I’m I thinking that through correctly? Correct... the '86 944T (951) ran early offset 7/8 x 16 wheels (Fuchs and Phone Dials) with an ET of 23.3mm front and rear. To run "late" offsets, you would need about 28 mm of spacers. 1" = 25.4mm so, 1-1.25" could work. Thanks for confirming. Now off to find spacers... |
Lo-Fi Version | Time is now: 9th May 2024 - 06:48 PM |
