FS: 1973 Marathon Blue 914 2.0, 1.7 Originally, includes original engine |
adolimpio |
Sep 10 2018, 03:43 PM
Art Group: Members Posts: 181 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
$27,000, cash or certified check
This was a barn find a few years ago in Salem Or. It had sat for 9 years and did not run. I put her on a trailer and brought her home to SC where I managed to breathe life into her. Although I love to drive her, I enjoy working on it more and there's virtually nothing left to do. Time to move on and find another one to play with. Pictures at: http://914.dolimpios.com/ Details: • Marathon blue with black interior • Originally a 1.7, but has been upgraded to 2.0 (original 1.7 engine retained) • COA on order • Engine runs perfectly, idles solid at 1K • Compression on cylinders: 1-130, 2-128, 3-128, 4-125 • Body is excellent, longs and hell hole are nearly perfect • Interior is nearly perfect. One small defect on passenger seat. • Visors rebuilt by 914 Rubber • Mileage is unknown • Everything works perfectly, lights, switches, blowers, heating, etc. • Within the past 5,000 miles the following was performed: - Transmission rebuilt - All transmission linkage bushings replaced - CV joints removed, cleaned, inspected, repacked and flipped - New clutch, flywheel and pressure plate - New accelerator cable - 911 swivel base valve adjusting screws installed - All calipers rebuilt - All brake rotors replaced - All wheel bearings replaced - Bushings on front swing arms and rear trailing arms replaced with Elephant Racing bronze bushings with grease fittings - All new shocks - Pedal cluster rebuilt - Headlights upgraded to amazing LEDs - Dash lights upgraded to LEDs - Top and bottom Targa top seals, all window seals, front and rear trunk seals replaced - Windshield washers upgraded with electric pump - Fog lights upgraded to function as daytime running lights - Interior rear view mirror upgraded to one with Homelink garage door openers and compass - Exterior mirrors polished and new glass installed - Cruise control installed • Known issues - Some rust on passenger side jack post support - Some rust on battery tray - Patched holes visible where someone had installed aftermarket mirrors - Small dimple on front trunk lid where someone apparently close it on something - Small defect on passenger seat - Scuff marks on roof • Also includes - Original 1.7 engine with complete FI and exhaust system - Original interior mirror and radio - Two extra transmissions, one in good working order the other a donor for parts - Numerous boxes of parts |
michael7810 |
Sep 24 2018, 11:27 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Nice looking car. Curious about the cruise control; would you mind sharing what system you used and how well it works. I just finished a 4200 mile journey in my 914 and that's one mod I wished I had.'
Thanks and GLWTS |
adolimpio |
Sep 24 2018, 01:24 PM
The Cruise Control is from a company called Rostra - http://www.rostra.com/
It works great. There is only one strange issue, when you first turn the unit on, you must press the brake or clutch once before it will engage. After that it engages promptly when pressing the Set switch. The trickiest part was mounting a switch on the pedal cluster so that the clutch will disengage the cruise. Here are some pictures: (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817059.1.jpg) Actuator mounted to top of air filter (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817060.2.jpg) Speed sensor - two magnets mounter on CV join and sensor mounted to transmission (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817062.3.jpg) Throttle linkage (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817063.4.jpg) Control mounted to shifter. It's menta to be mounted to the turn signal lever, but it was pretty bulky. I had to add a LED to the top so that I could see when it was turned on. The standard LED pointed straight up and could not be seen in daylight. |
michael7810 |
Sep 24 2018, 03:10 PM
The Cruise Control is from a company called Rostra - http://www.rostra.com/ It works great. There is only one strange issue, when you first turn the unit on, you must press the brake or clutch once before it will engage. After that it engages promptly when pressing the Set switch. The trickiest part was mounting a switch on the pedal cluster so that the clutch will disengage the cruise. Here are some pictures: (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817059.1.jpg) Actuator mounted to top of air filter (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817060.2.jpg) Speed sensor - two magnets mounter on CV join and sensor mounted to transmission (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817062.3.jpg) Throttle linkage (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1537817063.4.jpg) Control mounted to shifter. It's menta to be mounted to the turn signal lever, but it was pretty bulky. I had to add a LED to the top so that I could see when it was turned on. The standard LED pointed straight up and could not be seen in daylight. Thanks for the info |
Lo-Fi Version | Time is now: 24th May 2024 - 12:54 AM |
