Solvent for removing gaskets etc...? |
Bob Wolcott |
Jun 16 2005, 09:39 AM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
What is the best solvent or method for removing the remnants of gaskets and sealing agents (Loctite, etc...)? I removed my heads from the cam housing and I am trying to get the sealing surfaces clean before putting it back together.
Thanks, Bob |
Jakester |
Jun 16 2005, 09:44 AM
lurking instead of working Group: Members Posts: 101 Joined: 18-May 05 From: Palo Alto, CA Member No.: 4,097 |
scuffy pad on a die grinder = quick and shiney!
Any other way is laborious and painful, not to mention potentially hazardous to your gasket surface (e.g. scrapers). This solution assumes a few things 1) you have air 2) you have a die grinder 3) your surfaces are somewhat flat and accessible for a die grinder Since I've never dived into a TIV motor, I don't know what the surfaces you are referring to look like. I'm just speaking from general engine-work experience. |
Cap'n Krusty |
Jun 16 2005, 09:56 AM
In 30+ years of doing 911 motors, I've never found anything that'll remove the Kuril from the cam towers except hard work. Be VERY careful, you don't want to damage the seating surfaces in any way. Since you're in Mc Minville, why don't you run over and talk with Gary Emory? If anyone around there has a better way, it'll be him. We used to use a "cold tank" (straight carb cleaner, like you buy in the 5 gallon buckets at the parts store) which did the best job, but it's illegal in most places now. The Cap'n |
spare time toys |
Jun 16 2005, 11:33 AM
Loc tite makes a product called chisle. Works great just DO NOT get it on you. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
spare time toys |
Jun 16 2005, 06:21 PM
This is the stuff.
Cap'n Krusty |
Jun 16 2005, 06:28 PM
Might lift off gaskets and some adhesives, but 200K mile Kuril may be a different story. Carb cleaner and bead blasting hardly touch it .................... The Cap'n
Lo-Fi Version | Time is now: 3rd May 2024 - 06:12 PM |
