914 Rubber Fender Liner Clip Issue |
RickS |
Sep 10 2018, 11:03 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Let me first say I am a BIG supporter of 914 Rubber and appreciate their quality and customer service. Also like their new product development to help keep our aging teeners on the road and looking good. With that in mind I sent a message to their customer service inbox asking for help with rusting fender liner mounting brackets and the potential for the rust to spread to the sheet metal and haven’t received a reply.
So I am not calling them out, just kindly asking that they develop and provide rust proof replacement brackets. Love the fender liners but wish the rears dropped down further in front to keep debris from being thrown into the troublesome jack point area. I fabbed up some rugged plastic pieces to add to theirs to do just that, so I’m covered. Here are the brackets after two years on the west coast not driving in salt. |
RickS |
Sep 10 2018, 11:06 PM
jim_hoyland |
Sep 11 2018, 06:09 AM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I made brackets from a thin aluminum bar approx 1/8th thick, 1/2” wide and 6” long. By attaching one end of the bar to the chassis, the bar could move like a latch and make removal of the liners for cleaning (I have white liners). Can post a pic when car comes out of shop.
Mikey914 |
Sep 11 2018, 07:07 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These were spec'd out of stainless.
Apparently we need a recall. Drop me a PM with your specifics and I will get you replacements. Good news is that you can leave the liners in place and just drill the pop rivets out. My aplogies Mark |
RickS |
Sep 11 2018, 09:45 AM
Mark, being the stand up guy he is has already contacted me and will be shipping stainless replacements. Thanks Mark! And yes I will continue to shop with his great company.
sixnotfour |
Sep 11 2018, 10:11 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Good news , now they'll out last your 914 (IMG:style_emoticons/default/slap.gif)
JeffBowlsby |
Sep 11 2018, 10:17 AM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There is an electro-galvanic reaction between stainless and steel. Check the galvanic chart.
Close together is OK, far apart on the chart is problematic. Suggest thick aluminum as a better choice. Attached image(s) |
Mikey914 |
Sep 11 2018, 10:33 AM
Pretty sure this is not stainless as the rust seen should only be on the fastener.
Valy |
Sep 11 2018, 11:06 AM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
There is an electro-galvanic reaction between stainless and steel. Check the galvanic chart. Close together is OK, far apart on the chart is problematic. Suggest thick aluminum as a better choice. All good but the metal that rusts is the one on the right of the table. In this case, the stainless should not rust. I bet that's not a stainless bracket. |
tom.esh |
Sep 11 2018, 11:27 AM
Member Group: Members Posts: 62 Joined: 6-March 14 From: Canton Ohio Member No.: 17,083 Region Association: North East States |
I have seen some cheaper grades of stainless rust. Look at the stainless BBQ grills at the big box stores.
JeffBowlsby |
Sep 11 2018, 11:28 AM
To be clear, I agree with the idea that this is not a stainless bracket, its probably carbon steel, which is why its rusting.
What I am suggesting is that it should not be replaced with stainless stell because of the EG reaction between stainless and carbon steel. Recommend aluminum for this use. |
Sep 11 2018, 12:26 PM
To be clear, I agree with the idea that this is not a stainless bracket, its probably carbon steel, which is why its rusting. What I am suggesting is that it should not be replaced with stainless stell because of the EG reaction between stainless and carbon steel. Recommend aluminum for this use. I guess a stainless steel bumper means death for our cars. |
JeffBowlsby |
Sep 11 2018, 01:07 PM
No issue if they are isolated with the stock rubber spacers
Lo-Fi Version | Time is now: 17th May 2024 - 05:19 PM |
