Spray gun recommendations |
bbrock |
Sep 12 2018, 09:14 AM
I've been using the cheap Harbor Freight spray gun just to spray epoxy primer inside internal cavities that won't be seen, but now I need to get a better gun for the rest of the project. I'm leaning toward the Devilbiss StartingLine kit because it comes with a variety of tips but reviews are all over the matt. I'm pretty impressed with the results @aggiezig got with it. Eastwood's Concours 2 gun also caught my eye. Wondering what others might recommend. I want to keep the cost under $200ish. I'll be spraying PPG Deltron line paints (DCC single stage and DBC basecoat with DC clear) in silver metallic if that makes a difference.
Thanks! |
worn |
Sep 15 2018, 07:13 PM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I've been using the cheap Harbor Freight spray gun just to spray epoxy primer inside internal cavities that won't be seen, but now I need to get a better gun for the rest of the project. I'm leaning toward the Devilbiss StartingLine kit because it comes with a variety of tips but reviews are all over the matt. I'm pretty impressed with the results @aggiezig got with it. Eastwood's Concours 2 gun also caught my eye. Wondering what others might recommend. I want to keep the cost under $200ish. I'll be spraying PPG Deltron line paints (DCC single stage and DBC basecoat with DC clear) in silver metallic if that makes a difference. Thanks! That is the paint I use. I had better luck with the starting line than with the finish line guns. I have no idea why. |
bbrock |
Sep 15 2018, 08:26 PM
I've been using the cheap Harbor Freight spray gun just to spray epoxy primer inside internal cavities that won't be seen, but now I need to get a better gun for the rest of the project. I'm leaning toward the Devilbiss StartingLine kit because it comes with a variety of tips but reviews are all over the matt. I'm pretty impressed with the results @aggiezig got with it. Eastwood's Concours 2 gun also caught my eye. Wondering what others might recommend. I want to keep the cost under $200ish. I'll be spraying PPG Deltron line paints (DCC single stage and DBC basecoat with DC clear) in silver metallic if that makes a difference. Thanks! That is the paint I use. I had better luck with the starting line than with the finish line guns. I have no idea why. Well that's interesting. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 06:14 AM |
