From electric to a Subaru 3.6 swap, I'm the Suby guy who wandered into the 914 club |
Chi-town |
Nov 15 2018, 09:43 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Yeah I was being lazy and wanted to buy a complete unit.
Frank it's a piece of aluminum tubing with a piece of hose I can slide on it, about $5 from home Depot. You measure from the center to center of each cup (the deepest part), subtract 1/4 inch for plunging CV's, for non plunging it gets little more complicated. Measure both sides as they are almost never the same. |
Chi-town |
Nov 22 2018, 02:36 PM
Just an FYI to any other Suby swap guys, I just found 4 MR-2 shifters for around $30 each if anybody needs one to run cable shift.
strawman |
Nov 24 2018, 12:48 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Great progress. I ran a 4.11 Suby 5-speed Phase 1 transaxle out of a ‘98 Forester initially but ended going to a Phase 2 trans with 3.90 gears. I wish I could find a higher geared one; I’m cruising at about 3200 rpms at 70 mph. It might seem like you’re spinning that sixer a bit too high with 4.44 gears. Good luck with your project!
Tdskip |
Nov 24 2018, 06:54 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Subscribing - go Dylan go.
Chi-town |
Nov 24 2018, 09:44 AM
Strawman-. The gearing is for canyon runs, no top end needed. The EZ36 will spin 7k rpm all day with no issues.
Tdskip- slowly but surely (IMG:style_emoticons/default/laugh.gif) |
Chi-town |
Jan 15 2019, 04:39 PM
Been a while since I updated this so here goes..
Car is back on 4 wheels and rolling (without wheel dollies) for the first time in 14 years! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1084.photobucket.com-22446-1547592082.1.jpg) Front suspension is back together with Bilstien B6, Powerflex bushings in powder coated arms with Lemforder turbo tie rods and ball joints. I found out the PO had installed Sway-Away 22mm hollow torsion bars to deal with the weight of all the batteries, nice bonus! Still need to drill the hole for the front sway bar and get all the hardware plated to install it. Painted the 74' Boge housings to match the Bilstein dust covers. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1084.photobucket.com-22446-1547592083.2.jpg) Also finally installed my Nardi steering wheel with solid hub. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1084.photobucket.com-22446-1547592083.3.jpg) I've got a long list of things I need to button up with the chassis then I'll get back to the swap list. |
AndySomogyi |
Jan 29 2019, 11:26 AM
Newbie Group: Members Posts: 22 Joined: 29-January 19 From: Bloomington IN Member No.: 22,839 Region Association: Upper MidWest |
How does the oil pan depth of the EZ30 compare with the Type4 engine?
I've got a Porsche 912 and looking at swapping in either a EJ series or an EZ series. With the EJ, I can easily buy or make a lower profile oil pan. But with the EZ, looks like the pan is part of the block. |
Chi-town |
Jan 29 2019, 03:15 PM
The upper section of the pan is structural to the block, the lower section is a shallow steel pan.
Compared to a stock EJ pan I would say they are about the same depth, maybe just a pinch shallower for the EZ |
Mr. M |
Jan 30 2019, 02:35 PM
Newbie Group: Members Posts: 16 Joined: 16-May 17 From: Midwest Member No.: 21,111 Region Association: Upper MidWest |
This is a great build! The Subaru 3.6 is an awesome engine. Any new information on the production cradles?
Chi-town |
Apr 25 2019, 10:42 AM
I'm working with a very slow fabricator at the moment, hoping to have one test fit sometime next month.
In the mean time I've just been collecting all the misc parts it needed from all the parts cars I've gone through. I think I finally have everything I need. I did aquire a few goodies: H&R front sway bar Factory Rear sway bar Blaupunkt CR-4090 radio Some really clean tail lights Stainless steel brake lines Really nice seats A bunch of nos weather stripping Only work I've done is rebuilding the fog lights and swapping out old hardware for freshly plated ones (IMG:style_emoticons/default/laugh.gif) |
Tdskip |
Apr 25 2019, 10:43 AM
Go go go man! Let’s get this thing running for the sunner
nnowa07 |
Apr 30 2019, 02:21 PM
Newbie Group: Members Posts: 5 Joined: 11-April 19 From: San Miguel, CA Member No.: 23,034 Region Association: Central California |
I had the pleasure of picking up a roller from Chi-town and he's top notch! When it comes to subarus and 914s he knows his stuff. I'm selfishly waiting for this build to continue on so I can copy every thing he does. (IMG:style_emoticons/default/shades.gif) Keep up the good work!
Superhawk996 |
Apr 30 2019, 07:10 PM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
nnowa07 |
Jun 23 2019, 04:54 PM
Any updates?
Chi-town |
Jun 23 2019, 09:10 PM
I'm finally getting back to it after disassembling 13 parts cars and rebuilding one whole car.
I'll post some pics and misc later this week |
Chi-town |
Jun 26 2019, 10:42 PM
Pics will be up tomorrow but here's a short list of things that got done
Installed front sway bar and stainless brake lines with Endless CCRg pads Removed the clutch tube, accelerator cable tube, heater control tubes and center brace out of the tunnel to open it up for coolant lines. Mocked up the MR-2 shifter with a plate to bolt in the stock shifter location, need to work on extension. Installed a Blaupunkt CR4090 for that vintage look, had to repair the firewall bracket. Swapped out a bunch of hardware and latches for freshly plated ones Swapping out the torsion style LSD for a Plated unit as soon as I get the friction plates WPC treated. It's nice to get back to work on it |
djway |
Jun 26 2019, 11:34 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Good to see the lil gal gettin some attention (IMG:style_emoticons/default/smile.gif)
nnowa07 |
Jun 28 2019, 12:35 PM
woohoo! Any news on that 3.6 cradle?
76-914 |
Jan 27 2020, 09:57 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Any progress updates? (IMG:style_emoticons/default/beerchug.gif)
JRust |
Jan 27 2020, 10:19 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Yes 3.6 motor updates please
Lo-Fi Version | Time is now: 15th May 2024 - 07:41 PM |
