removing carbon from heads, what is the best method? |
Bob Wolcott |
Jun 16 2005, 11:56 AM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
What is the best way to clean carbon from the valves and heads of a 911 engine?
Thanks, Bob |
tat2dphreak |
Jun 16 2005, 11:59 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
B12 carb clean and a light wire brush, or abrasive (bead) blasting(what the shops use)...
SLITS |
Jun 16 2005, 12:25 PM
glass bead.....doesn't remove metal...just deposits |
xsboost90 |
Jun 16 2005, 12:34 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
take it out and run it hard...w/ some emissions cleaner in there, works every time..oh off the car. Soak it in cider. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Dr. Roger |
Jun 16 2005, 01:26 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
With the heads on or off the car? |
redshift |
Jun 16 2005, 01:29 PM
I dunno bout air coolers... but we used to dump a gallon of hot soapy water down the hole on V8s with the pedal down pretty far...
POW! POW!~ exhaust sized chunks. M |
Dr. Roger |
Jun 16 2005, 02:09 PM
Yep, done that. It's kinda' fun. When I was working as a "test fuel additive rater" in the Test Fuels Additive Lab at Chevron for a couple of years, I learned that the quickest "clean up" additives were the ones with the highest percentages of Techron/Techroline. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) There was a point of diminishing returns. Yes we did test other competitors additives but there was only one better than techron at that time. Amoco "Clear" was #1 back then. Only sold back east. Shifting gears.......... Glass beads are great as long as they are COMPLETELY removed from the heads once blasted. They have the potential of being very nasty if there are residual beads. The "One bottle and pass" stuff does work. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) My old '72 Chevelle appreciated it and so did I. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
spare time toys |
Jun 16 2005, 06:09 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I use these pads made by 3M they have them in green and white. They are 2 in dia. and clean carbon and gaskets like crazy.
Attached image(s) |
spare time toys |
Jun 16 2005, 06:10 PM
Before and after I have cleaned up 1 head in this shot
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:35 PM |
