GB door stay pin. Is your door popping?GB closes 10/4/18 midnight, $8 a set of 2 or $44 for entire kit- both doors including these |
Mikey914 |
Sep 19 2018, 11:42 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time).
So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Attached thumbnail(s) Attached image(s) |
Mikey914 |
Sep 29 2018, 10:23 PM
The mode of failure is actually galvanic corrosion. It takes metal off the pin and aluminum. My pins still fit the bracket.
Lo-Fi Version | Time is now: 3rd May 2024 - 12:53 PM |
