head light switch, what pins go to ? |
imapayne |
Sep 20 2018, 11:04 AM
Newbie Group: Members Posts: 20 Joined: 15-February 16 From: Oregon Member No.: 19,676 Region Association: Pacific Northwest |
My 75 1.8 914 is finally coming together but headlight switch is killing me. on the back pins are marked but not sure which wire goes where. I have the nice plastic wire sche and Haynes manuel but its not much help. Thanks Imapayeb
ClayPerrine |
Sep 20 2018, 01:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Nice engine, but somehow I don't think it came from a 914. (IMG:style_emoticons/default/biggrin.gif)
porschetub |
Sep 20 2018, 01:32 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Nice engine, but somehow I don't think it came from a 914. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) they seem to end up in them however. Go to Jeff Bowlsby's website heeps of info on there,thanks to Jeff his wiring diagrams have been a huge help to me. There are 2 types of switches early and late,from memory one has 10pins and the other 11,good luck. |
JeffBowlsby |
Sep 20 2018, 02:14 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You will need to use the FWSM schematics to get the wiring straight. Each model year is different.
imapayne |
Sep 20 2018, 02:42 PM
Im sorry but what is the FWSM sche. how do i change that pic lol
imapayne |
Sep 20 2018, 03:24 PM
ClayPerrine |
Sep 20 2018, 08:43 PM
jcd914 |
Sep 20 2018, 09:31 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Im sorry but what is the FWSM sche. how do i change that pic lol FWSM - Factory Workshop Service Manual There used to be the factory diagrams on the Pelican Part website but then the links were broken, not sure if they got fixed. What year is your car? You can always go back to your original post and edit it, look at the bottom right corner of the post for the "Edit" button. Jim |
ClayPerrine |
Sep 20 2018, 09:33 PM
Im sorry but what is the FWSM sche. how do i change that pic lol FWSM - Factory Workshop Service Manual There used to be the factory diagrams on the Pelican Part website but then the links were broken, not sure if they got fixed. What year is your car? You can always go back to your original post and edit it, look at the bottom right corner of the post for the "Edit" button. Jim You can still find them in the internet archive... aka the wayback machine. |
imapayne |
Sep 22 2018, 05:21 PM
Ive never heard of the way back machine but would love to use. Can someone point me to a work around so i can use it Thanks
ClayPerrine |
Sep 22 2018, 06:12 PM
Ive never heard of the way back machine but would love to use. Can someone point me to a work around so i can use it Thanks Internet Archive, AKA The Wayback Machine Find the dead link on Pelican's site, then open it from a couple of years ago on the Wayback machine. |
imapayne |
Sep 28 2018, 02:42 PM
can anyone tell me what pins on the switch are power? and other pins i have the running lights figured out.
DashSwitches.pdf ( 127.27k )
its the first light switch |
JeffBowlsby |
Sep 28 2018, 04:54 PM
Here you go. This is only correct for the 1975 cars.
Attached image(s) |
porschetub |
Sep 29 2018, 05:44 PM
Jeff to the rescue,well done ,I bypassed the dimmer control as I have had two fail,it not like you would use it as on maximum it's not great ,if you go to LED lamps you can't use it anyway,LED lamps are a good cheap upgrade and worth doing,cheers.
imapayne |
Oct 1 2018, 03:18 PM
Thanks That did it.
imapayne |
Oct 3 2018, 09:22 PM
Its alive pulled injectors flushed reinstalled pulled dist adjusted points reinstalled fixed vacuum leaks with a cornwell leak detector which smoke leaks. Used on leaking gas on new cars. And it purrs like a kitten. Ill show photos after upholstery install.
Lo-Fi Version | Time is now: 29th April 2024 - 08:04 PM |
