Lost reverse and sometimes first gear, Just replaced bushings in the linkage |
milwlandrover |
Sep 21 2018, 11:51 AM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
I replaced the linkage and the shifting was sloppy but at least I could find each of the 5 gears and reverse. After driving it around a little I had problems hitting reverse when I parked this morning. By lunch I went out and could not find reverse at all. I pushed it the few feet I needed to back up and drove away, but first gear was hard to find. Is there an adjustment that I missed. I ordered the Precision Shift Adjuster but it has not arrived yet. I figure that will "fine tune" the shifting but I would like to have the linkage as close as I can prior to adding the PSA. Thanks in advance for your help.
cheers! and happy last day of summer! markw |
ChrisFoley |
Sep 21 2018, 12:45 PM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I replaced the linkage and the shifting was sloppy but at least I could find each of the 5 gears and reverse. After driving it around a little I had problems hitting reverse when I parked this morning. By lunch I went out and could not find reverse at all. I pushed it the few feet I needed to back up and drove away, but first gear was hard to find. Is there an adjustment that I missed. I ordered the Precision Shift Adjuster but it has not arrived yet. I figure that will "fine tune" the shifting but I would like to have the linkage as close as I can prior to adding the PSA. Thanks in advance for your help. cheers! and happy last day of summer! markw Adjuster should show up in the mail tomorrow. It sounds like something is loose, allowing the lever to move more than normal. Check both bushing brackets, the one under the shift lever and the one at the transmission. Also check the cone screw below the shift lever. |
milwlandrover |
Sep 21 2018, 01:18 PM
[I am on it. Thanks for your help and fast service.
Cheers! |
milwlandrover |
Sep 24 2018, 09:21 AM
[I got the precision shift adjuster yesterday. It looks great. I probably won't get it in until next weekend, but I appreciate your service and the hard work that went into the part.
cheers! markw |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:17 PM |
