FOUND: Targa Top Rear Pin/rubber block |
Nogoodwithusernames |
Sep 21 2018, 01:11 PM
Member Group: Members Posts: 236 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Hi all, I need a good set of the rear targa pins with the rubber blocks. Both of mine are shot and the rubber blocks are falling off. Pelican parts has some but not sure of URO's quality on those so I'd like to find some OEM ones if possible in good condition.
bdstone914 |
Sep 21 2018, 05:58 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Nogoodwithusernames
Note the width and height difference. ID which you have. The wrong one wil either have the top sit low and move side to side or sit high and not fit into the rear latches. |
bdstone914 |
Sep 21 2018, 06:01 PM
@Nogoodwithusernames Note the width and height difference. ID which you have. The wrong one wil either have the top sit low and move side to side or sit high and not fit into the rear latches. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 03:00 PM |
