> Installing Oil Strainer Housing Gaskets, Dry or Wet with Oil
motorvated
post Sep 22 2018, 06:00 PM
Cleaned out the strainer and ready to install the two new large paper gaskets. My question is whether I should install them dry, or should I put a thin smear of engine oil on them first.
Replies(1 - 6)
ClayPerrine
post Sep 22 2018, 06:13 PM
Dry. And don't forget to replace the aluminum crush washer under the bolt head.
motorvated
post Sep 22 2018, 06:15 PM
QUOTE(ClayPerrine @ Sep 22 2018, 06:13 PM) *
Got it. Thanks!
bandjoey
post Sep 22 2018, 10:08 PM
bandjoey
And don’t forget the super low torque. Something like 8lbs. Someone will jump in with exact or check your Haynes book.
Mark Henry
post Sep 23 2018, 06:32 AM
that's what I do!
QUOTE(bandjoey @ Sep 23 2018, 12:08 AM) *
9 lbs, if you change your own oil an inch pound torque wrench is a wise investment.
ottox914
post Sep 23 2018, 08:12 AM
The glory that once was.
Its good to have several ranges of TQ wrenches in the drawer. Dig thru pawn shops to find some hidden gems is smaller ranges.
TheCabinetmaker
post Sep 23 2018, 08:28 AM
I drive my car everyday
If i bought a torque wrench from a pawn shop, Id have it calibrated before using it. They don't like being dropped. They should also be kept in the case and returned to 0 when stored. I attended a calibration class as part of my Air Force jet mechanic tech school. We did a lot of test on them. You would not believe how much one can change when dropped on it's head on concrete from 4 feet.
- Lo-Fi Version Time is now: 16th April 2026 - 10:25 AM
