identify front shocks |
JFG |
Sep 23 2018, 05:19 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i'm looking at new front shocks for my 74 but all the images are of just straight damper units. i know generic library images are used often but i'm a tad confused.
the picture shows the hub/stub axle is welded to the damper. i have found an image of this but it's listed as 911. can someone explain what i have / should have? the rotors are 4 stud all around. |
mepstein |
Sep 23 2018, 06:02 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 914 front strut takes a shock insert. What you are seeing is the housing. the shock is inside and called a front strut insert. The insert can be replaced without removing the entire strut.
Mark Henry |
Sep 23 2018, 06:07 AM
Often called a cartridge, the shock drops into strut. You can't see the front shock when it's installed. |
burton73 |
Sep 25 2018, 01:46 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I just happened to have one close by to take a picture of. A complete front 911 Carrera setup that I bought from Dave – Toolguy.
Bob B (IMG:style_emoticons/default/wub.gif) |
JFG |
Sep 26 2018, 10:02 AM
thanks for that info. does the shock cartridge just sit inside the outer tube or does it screw in?
mepstein |
Sep 26 2018, 10:11 AM
thanks for that info. does the shock cartridge just sit inside the outer tube or does it screw in? It drops down inside and a lock ring tightens down over top of the cartridge. You con use a lock ring spammer or a pipe wrench to remove. Sometimes it can be very stubborn and some heat (propane or map gas) on the tube near the top can aid with removal. |
burton73 |
Sep 26 2018, 10:47 AM
thanks for that info. does the shock cartridge just sit inside the outer tube or does it screw in? It drops down inside and a lock ring tightens down over top of the cartridge. You con use a lock ring spammer or a pipe wrench to remove. Sometimes it can be very stubborn and some heat (propane or map gas) on the tube near the top can aid with removal. I just happened to have a picture. Bob B |
Lo-Fi Version | Time is now: 5th May 2024 - 02:52 AM |
