Fuse Box from JWest Engineering ? |
Beakster |
Sep 23 2018, 06:33 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
I just bought one of these JWest Engineering Fuse Box Panels .. Is there anyone out there that has installed one .. I'm looking for your feed back .. Thanks
Larmo63 |
Sep 23 2018, 06:46 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
There should be tons of threads here on this subject....
Coondog |
Sep 23 2018, 06:57 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
ConeDodger |
Sep 23 2018, 07:01 PM
Apex killer! Group: Members Posts: 23,578 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
20 minutes and done... works like a charm.
DRPHIL914 |
Sep 24 2018, 09:22 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
did not take too long, I had a short and some hacked wiring, so it was a good way to clean up the rats nest and prevent a fire or short, and modern fuses , I;m not knocking fuses loose with my knee and you can use the lighting up ones that show up if it blows.
I think its a good idea if you don't need a concours original panel for show. |
ConeDodger |
Sep 24 2018, 09:37 PM
did not take too long, I had a short and some hacked wiring, so it was a good way to clean up the rats nest and prevent a fire or short, and modern fuses , I;m not knocking fuses loose with my knee and you can use the lighting up ones that show up if it blows. I think its a good idea if you don't need a concours original panel for show. No PCA concours is going to judge you on your fuse panel. (IMG:style_emoticons/default/smile.gif) |
larryM |
Sep 28 2018, 08:51 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
i can attest to that (except at PCA Parade - where a-retentive types look at screw heads & such) just keep track of wires positions & colors (not all harnesses have exactly the same colors that match published diagrams) it is a tight vertical fit - but a superb upgrade |
porschetub |
Sep 29 2018, 01:25 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have one to fit which I bought from a member on here,then I hear some folks saying the don't like the fact the wiring gets some strain on it due to the position pins on the panel,how real is this issue ? my wiring has no hack jobs and is in great condition but I don't want to fit one and create a problem.
Lo-Fi Version | Time is now: 7th May 2024 - 09:24 PM |
