Lift Tips, do's & don'ts / tips & tricks since owning a lift |
76-914 |
Sep 24 2018, 11:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've owned my lift for 2 years come November and along the way I've found a few things worth sharing. Feel free to add your own tips here especially if they involve safety.
1) I took almost a year to realize that I wouldn't be upright under my car while working like you see in the advertisements. Oh sure, I do some work upright but for the most part it is very uncomfortable and results in a stiff neck. So, raised appx 2' I use my creeper as it is much more comfortable to work while laying than upright. 2) It was another year before I learned that the best benefit of having this lift was to raise the car appx 2ft off the ground so I don't need to bend over for hours at a time resulting in a back ache. 3) Clear the area below before lowering your lift. Twice! 4) Clear the area above before raising. 5) Jack Extensions - My MaxJax comes with 4" lift extensions to give you a little more headroom however these can't be fitted beneath the 914 because it sits so low. I need to lift it a few inch's with the lift then lower it upon blocks. Only then is there enough room to insert the extensions. I can't use wood blocks under the longs to hold it higher because I have fiberglass valance covers. So I placed blocks beneath the wheels instead. This doesn't work worth a Continental Damn because of the 914's suspension. As I lowered the car it would walk to the side if the fronts touched ground 1st of it would walk forward if I'd left the Ebrake on or left it in gear. A couple of times I thought the tire would slip off one of the blocks as it was lowered. I cured that yesterday. HF had the 12"x18" furniture dollies on sale for $7 so I now have 4 of those to place beneath the wheels when using the extensions. Cheaper than the purpose made dollies that sell for about $40 each and rated at 1000 lbs. Much safer now. 6) Don't leave your car on the lift unnecessarily especially if you live in Earth Quake regions. 7) Use the lift's safety catch's or safety lock outs. (IMG:style_emoticons/default/beerchug.gif) |
iankarr |
Sep 24 2018, 02:01 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,477 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
This is a great idea for a thread. Thanks for starting it!
I totally agree that the ideal height range is 18" - 2 feet. Working overhead seems like it would be easier, but it isn't. Tips I'd add... – The first time you lift your car, you'll feel stupid for not buying one sooner. – Before lifting, raise the pads to an inch or so before they make contact with the car, and adjust as needed. It's amazing how things don't line up the way you think they will. – Where possible, always use jackstands as a backup in case the lfit fails. I like to put them under the engine bar and a-arms. (AND REMEMBER TO REMOVE THEM WHEN LOWERING (IMG:style_emoticons/default/wink.gif) – Only use approved lifting points. – Put all tools you think you may need on the ground near where you're working. And still, you'll find yourself having to get up because you forgot something. – Always keep your cell phone handy, in case you need help under the car. – Most importantly, be safe! |
KELTY360 |
Sep 24 2018, 04:58 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
This is a great idea for a thread. Thanks for starting it! I totally agree that the ideal height range is 18" - 2 feet. Working overhead seems like it would be easier, but it isn't. Tips I'd add... – The first time you lift your car, you'll feel stupid for not buying one sooner. – Before lifting, raise the pads to an inch or so before they make contact with the car, and adjust as needed. It's amazing how things don't line up the way you think they will. – Where possible, always use jackstands as a backup in case the lfit fails. I like to put them under the engine bar and a-arms. (AND REMEMBER TO REMOVE THEM WHEN LOWERING (IMG:style_emoticons/default/wink.gif) – Only use approved lifting points. – Put all tools you think you may need on the ground near where you're working. And still, you'll find yourself having to get up because you forgot something. – Always keep your cell phone handy, in case you need help under the car. – Most importantly, be safe! This pretty much nails it, except I like working on a rolling stool instead of laying on a creeper. That requires a working height of about 3'. Being able to walk upright under the car is great for inspecting stuff. It's easy enough to lower for working on it. Having a lift makes detailing wheels and tires a breeze....truly decadent. |
Lo-Fi Version | Time is now: 24th May 2024 - 10:00 AM |
