Green Instrument Light/Alternator, Troubleshoot |
xperu |
Sep 24 2018, 02:07 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
My alternator light came on so before I look into a replacement, is there any troubleshooting I should do first? Thanks Mike Kelly
Spoke |
Sep 24 2018, 04:05 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
As stated, check the belt first.
If the belt is ok and tight, do the following 4 voltage measurements with the engine running at idle: 1) Battery voltage from battery terminal POS to chassis (not battery negative) 2) On the voltage regulator plug, measure DF to chassis 3) On the voltage regulator plug, measure D+ to chassis 4) On the voltage regulator plug, measure D- to chassis |
bigaadams |
Sep 25 2018, 07:51 AM
Newbie Group: Members Posts: 3 Joined: 12-October 17 From: GA Member No.: 21,503 Region Association: South East States |
As stated, check the belt first. If the belt is ok and tight, do the following 4 voltage measurements with the engine running at idle: 1) Battery voltage from battery terminal POS to chassis (not battery negative) 2) On the voltage regulator plug, measure DF to chassis 3) On the voltage regulator plug, measure D+ to chassis 4) On the voltage regulator plug, measure D- to chassis Perhaps you could go a step farther and explain to the poster what voltages are to be expected at each reading point you have posted....and the cause (suspected problem) if voltages fall outside this range. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 AM |
