Gas tank and fuel line questions, I pulled and cleaned my tank! |
bmtrnavsky |
Sep 24 2018, 02:37 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
I have a VERY clean tank in my 72 2.0 now!
Ok... after 5 years of sitting 1/2 full of fuel in the humidity of East Texas I had some issues... here is what I did. first I pulled the tank drained it completely and washed it. To get it clean I dumped about 5 gallons of boiling water and Cascade dishwasher soap in it and sloshed it around. this did a FANTASTIC job of washing ut all the fuel residue and sludge from the bottom. Then I noticed there was rust in the bottom of the tank mostly right at the fuel return and pickup. It was gross, but I tapped on it with a small piece of rebar to knock off the loose stuff then filled the talk with about a gallon of Evapo-Rust. Let me tell you this stuff was FANTASTIC!. for a couple days I kept blocking and rotating the empty tank and treated all the rust. The tank is now a shiny silver grey with a touch of black where the worst rust was. Then I fogged the interior of the tank with SeaFoam to keep it from rusting. The aerosol kind you shoot down throttle bodies was awesome here. The tank is now rust free, sanded and painted as are the expansion tank and charcoal filter. Everything looks clean and pretty. BUT I had to cut some fuel lines to get the tank out... First is it possible to put it back in wrong? I don't think it is because there are two different sized hoses. Second what size hose the local parts stores seem to have inch sizes what is the metric and standard conversion? It's all new in the engine compartment, but this hose was 40 years old so I figure I should get'r done. How much of each should I buy? There is a little Y shaped thingy down below I can not tell what it was hooked up to? My pump and filter are near the steering rack now if that helps answer any of these questions. Do I need to replace the TINY hose that goes up by the gas cap? What do I use here and what size is it? I have plastic fuel lines in the longs. Can I or should I pull and replace these with rubber fuel line? Finally... I have a new battery in and am about to have fresh fuel... is there anything besides clean oil I should be looking at before I fire it up? everything seems to work when you turn the key. It turns over strong, lights, radio etc seem to work, and brakes work. I'd like to take it for a few laps around the neighborhood tonight if I manage to get it started. If anyone has a diagram of how these fuel lines go that would be a BIG help. |
Amphicar770 |
Sep 27 2018, 05:49 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Biggest PIA was getting tank back in without kinking lines. Harbor Freight borescope camera was a huge help.
http://www.914world.com/bbs2/index.php?showtopic=282633 |
Lo-Fi Version | Time is now: 16th May 2024 - 02:53 AM |
