Replacement oil sender question |
dgraves |
Sep 24 2018, 03:56 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
My '74 2.0 914 has a 911 dash instrument panel with a Druck Pressure gauge. I have confirmed that my oil pressure sender unit has failed. I'm assuming that a Druck oil pressure gauge and sender is not standard factory equipment for a 914. How do I know what sender to buy?
Thanks, guys. I really miss my pressure gauge not working. Dan |
914Sixer |
Sep 24 2018, 04:49 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You need the 911 sender for the gauge. Look over at the Pelican 911 section, think there is a cross reference table there. What is the part number on the one you have? It should tell you the Kpa or lbs. Your info should all be on the sender.
dgraves |
Sep 24 2018, 06:58 PM
You need the 911 sender for the gauge. Look over at the Pelican 911 section, think there is a cross reference table there. What is the part number on the one you have? It should tell you the Kpa or lbs. Your info should all be on the sender. Thank you, Mark. Any idea where the part number might be. I'm hoping I don't have to pull it off yet...still enjoying a few more days before snow in Montana. |
bdstone914 |
Sep 24 2018, 09:47 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You need the 911 sender for the gauge. Look over at the Pelican 911 section, think there is a cross reference table there. What is the part number on the one you have? It should tell you the Kpa or lbs. Your info should all be on the sender. Thank you, Mark. Any idea where the part number might be. I'm hoping I don't have to pull it off yet...still enjoying a few more days before snow in Montana. Get the part number off of the gauge. It is seen thru the glass in the very outer edge. With that you can match to the correct sender. What is the range? Bruce @914sixer @dgraves |
dgraves |
Sep 25 2018, 01:32 PM
You need the 911 sender for the gauge. Look over at the Pelican 911 section, think there is a cross reference table there. What is the part number on the one you have? It should tell you the Kpa or lbs. Your info should all be on the sender. Thank you, Mark. Any idea where the part number might be. I'm hoping I don't have to pull it off yet...still enjoying a few more days before snow in Montana. Get the part number off of the gauge. It is seen thru the glass in the very outer edge. With that you can match to the correct sender. What is the range? Bruce @914sixer @dgraves Bruce, the range of the gauge is 1 to 5. I can't see a number through the gauge. Will I have to look on the back side of the cluster? |
Lo-Fi Version | Time is now: 22nd May 2024 - 07:39 AM |
