Replacement oil sender question |
dgraves |
Sep 24 2018, 03:56 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
My '74 2.0 914 has a 911 dash instrument panel with a Druck Pressure gauge. I have confirmed that my oil pressure sender unit has failed. I'm assuming that a Druck oil pressure gauge and sender is not standard factory equipment for a 914. How do I know what sender to buy?
Thanks, guys. I really miss my pressure gauge not working. Dan |
porschetub |
Sep 25 2018, 02:18 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
From memory the 1 to 5bar unit wasn't used for long on ROW 911's, so of course the 80psi sender is the correct one,shop around the senders can range from crazy expensive to reasonable,I'am running a 150psi VDO dual function one that has the higher pressure warning of 10psi,good peace of mind solution IMO.
Bought mine on ebay for $35 some time ago and have had no issues,only thing I didnt like was the plastic thumbscrews so replaced them with small nylock nuts. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:51 PM |
