Machine Shop recommendation, Knoxville, TN |
Mblizzard |
Sep 28 2018, 11:24 AM
Working through the various options on how to proceed with my next version of my build. One thing I am looking at is potentially having some work one on the case. Any recommendations on local (Knoxville, TN) shops that can open the case to accommodate bigger cylinders. Believe the opening has to go from 98mm to 103mm.
Also may need to have lined bored. |
DRPHIL914 |
Sep 28 2018, 11:49 AM
no recommendations from me other than there is a guy here that could build your motor for you --- Go Big or Go Home Mike!!! (IMG:style_emoticons/default/poke.gif)
Mblizzard |
Sep 28 2018, 12:42 PM
no recommendations from me other than there is a guy here that could build your motor for you --- Go Big or Go Home Mike!!! (IMG:style_emoticons/default/poke.gif) Looks like I will be doing the build with a lot of Type 4 Store goodies including Nickies and lots of questions for the brain trust. Oh it will be big! |
poorsche914 |
Sep 28 2018, 01:16 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Mike,
There is a VW show Oct 6-7 in Sevierville. I can ask about nearby shops with aircooled experience. Or, contact Eurotech Knoxville - if they don't do it in house, they may be able to recommend a shop. steve (IMG:style_emoticons/default/driving.gif) |
914dave |
Sep 28 2018, 03:48 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Mike
What did it turn out to be. Broken crank or cranks bolts? Dave |
Mblizzard |
Sep 28 2018, 04:31 PM
914dave |
Sep 29 2018, 06:07 AM
I hear ya! You already know it won’t be pretty! Get in there and post some pics!!!!
poorsche914 |
Sep 29 2018, 07:50 AM
Give Larry a call at The Speed Shop in Harriman (865) 882-0093
bdstone914 |
Sep 29 2018, 08:01 AM
Mike,
Let me know if you need a case. I have one that is cleaned and does not need line bore. Please share pictures of the carnage. @Mblizzard |
Mblizzard |
Sep 30 2018, 12:58 PM
Let the carnage begin!
Not sure this is the cause but it did not help. I did not note if it was in this position when I removed it because the crank fell out. But it looks like someone put it in wrong and then repositioned. |
mb911 |
Sep 30 2018, 03:53 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Wow that sucks. Looks like a total loss to me..
IronHillRestorations |
Sep 30 2018, 08:53 PM
Whoopsie! Looks like a main bearing didn't get lined up on the dowel pin
wndsrfr |
Sep 30 2018, 09:14 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
If you're going to go big...take Bruce's case, send it to FAT and have them put in a new forging stroker crank balanced and doweled to the flywheel and pressure plate. BTDT...Also, They'll deck the case and set it up for bigger spigots if you want to go bigger than 96mm.
90quattrocoupe |
Sep 30 2018, 11:22 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Are 914 cranks forged or cast?
Greg W. |
mb911 |
Oct 1 2018, 05:04 AM
Maybe 6 time might br cheaper.
Mblizzard |
Oct 1 2018, 06:51 AM
mb911 |
Oct 1 2018, 07:25 AM
Maybe 6 time might br cheaper. Really don't see any way I could do a 6 conversion for the money. Currently just looking at just building it back with a few more quality parts like Nickies and such. Mike I have no idea what it costs to do a type 4.. I have heard large numbers semi recently. I then think of some of the 3.0 and smaller that Mark Epstein has had for sale recently and your almost at a wash. Probably still 3k more expensive for a swap of a known running 6 engine.. |
Mblizzard |
Oct 1 2018, 08:15 AM
Maybe 6 time might br cheaper. Really don't see any way I could do a 6 conversion for the money. Currently just looking at just building it back with a few more quality parts like Nickies and such. Mike I have no idea what it costs to do a type 4.. I have heard large numbers semi recently. I then think of some of the 3.0 and smaller that Mark Epstein has had for sale recently and your almost at a wash. Probably still 3k more expensive for a swap of a known running 6 engine.. I have not seen any essentially plug and play 6 that is even close to what I expect to spend on this build. I am essentially spending $5K on good parts from the Type 4 Store, will have some machine shop work in it, and doing the build myself. I have seen some rebuildable 6s that would fall in that range but nothing ready to go. Anyone has a good running 6 ready to go for $8K then that's a game change. But I just have not seen anything like that. |
Mblizzard |
Oct 1 2018, 08:43 AM
If you're going to go big...take Bruce's case, send it to FAT and have them put in a new forging stroker crank balanced and doweled to the flywheel and pressure plate. BTDT...Also, They'll deck the case and set it up for bigger spigots if you want to go bigger than 96mm. This is an interesting option. My current case has already be taken 0/20 over. But the shipping just makes it difficult to do. |
Mblizzard |
Oct 1 2018, 09:32 AM
Mike, Let me know if you need a case. I have one that is cleaned and does not need line bore. Please share pictures of the carnage. @Mblizzard Bruce just trying to work through some costs. Thoughts on taking the case and having it opened to accommodate a 78mm crank (not suppose to require any mods but I have not done this before) and open the case to 108.50mm to accommodate large cylinders and then shipping. Checking with some shops here but they just done have much experience with Type 4 case work so it would be hit or miss! |
Lo-Fi Version | Time is now: 17th May 2024 - 02:34 PM |
