brake & front light issue |
JFG |
Oct 1 2018, 09:50 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i have the euro light set up on the front of my car but i found an issue today.
all lights work normally on the exterior independently. today i saw my front side lights illuminate when i press the brake pedal, the brake lights come on also . the only other quirk i have is that when i indicate left or right the 2 arrows on tje gauge flash once then stop but outside lights work as normal. these arrows work when i use the hazard flashers. if i remember correctly i used a diagram from jeff bowlsby website for the wiring and i'm sure this has only just started as i've checked my lights numerous times |
Lo-Fi Version | Time is now: 17th May 2024 - 04:48 AM |
