lense repair |
lense repair |
JFG |
Oct 2 2018, 08:51 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i have a slight tear/crack in the amber lense on my back light. it's a new hella lense so i need the make every effort to save it.
what is the best/best type of glue to use? |
76-914 |
Oct 2 2018, 09:16 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Interesting. (IMG:style_emoticons/default/popcorn[1].gif) No help here but I'd like to know as well. (IMG:style_emoticons/default/beerchug.gif)
Oct 2 2018, 09:20 AM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I repaired a cracked euro lens. Super glue the crack and then sand and polish. It won't disappear but it can be made better.
dr914@autoatlanta.com |
Oct 2 2018, 09:28 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The design of the original lens required that the segments be glued. For years they have Come apart and would need to be re glued. Also the segments would not always line up correctly and the buckets would warp after years of use, so proper alignment was always a problem, even now.
Here is the glue to use, even Hella used it: |
JFG |
Oct 2 2018, 11:02 AM
thanks for the info, i was hoping this would do it as i have an unopened tube in the cupboard
https://www.toolstation.com/shop/Adhesives+...Adhesive/p80659 i won't use a generic superglue as i've found it discolours plastic. the split is not in a join but just under the moulding for the retaining bolt thread. |
JFG |
Oct 2 2018, 11:15 AM
what about this?
https://uk.rs-online.com/mobile/p/acrylic-adhesives/0144406/ i don't know what type plastics are used in light manufacture. |
Jamie |
Oct 2 2018, 12:05 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I repaired a cracked euro lens. Super glue the crack and then sand and polish. It won't disappear but it can be made better. Superglues are not the best choice for bonding plastics, the joints are brittle and crack easily. Plastic glues are a far better choice because they fuse with the plastics, and epoxies remain somewhat more elastic than superglues. |
Oct 2 2018, 12:10 PM
I repaired a cracked euro lens. Super glue the crack and then sand and polish. It won't disappear but it can be made better. Superglues are not the best choice for bonding plastics, the joints are brittle and crack easily. Plastic glues are a far better choice because they fuse with the plastics, and epoxies remain somewhat more elastic than superglues. I’m sure your right but I didn’t want to put real money into the repair. Just diy so it looked decent and usable. It did seem to work fine. |
bbrock |
Oct 2 2018, 12:58 PM
Use something similar to what George recommended. I used Weld-on brand. You want a solvent weld for acrylics. I went to the local glass shop and they gave me an opened tube for free. There are different viscosities and for a crack, you want a thin, watery version that you apply with a needle so it can seep into the crack. Mine was broken at the original glue joint. Here's the result.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1514096163.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-20845-1515857852.jpg) I also repaired a crack using the needle method but don't have a pic. Worked great though. The trick is to clamp the pieces or crack together tight and then apply the solvent so it gets sucked into the crack by capillary action. The perfect amount fills the area without any excess. Too much, and the solvent melts whatever it touches to leave a visible blemish. Too little and you have voids that will be visible. A good repair is invisible or close to it. |
burton73 |
Oct 2 2018, 02:19 PM
burton73 Group: Members Posts: 3,525 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
what about this? https://uk.rs-online.com/mobile/p/acrylic-adhesives/0144406/ i don't know what type plastics are used in light manufacture. In the UK that is what you get. Here in the states the pros use a different material. I am a pro. George do you keep yours in the refrigerator? It goes bad in a hot climate. Let it warm up to room temperature. Brent had the right idea but cracked plastic is in no way easy to repair as the glued parts that have come apart. Bob B |
JFG |
Oct 2 2018, 02:29 PM
i've never had much luck glueing plastics but i'm not paying another £150 for a lense if i can help it.
Thanks for the advice, i'll pick some of the rs glue up and see how it goes. (IMG:style_emoticons/default/beerchug.gif) |
Oct 2 2018, 02:31 PM
absolutely in the refrigerator!!!!
76-914 |
Oct 2 2018, 03:09 PM
absolutely in the refrigerator!!!! what about this? https://uk.rs-online.com/mobile/p/acrylic-adhesives/0144406/ i don't know what type plastics are used in light manufacture. In the UK that is what you get. Here in the states the pros use a different material. I am a pro. George do you keep yours in the refrigerator? It goes bad in a hot climate. Let it warm up to room temperature. Brent had the right idea but cracked plastic is in no way easy to repair as the glued parts that have come apart. Bob B OT: a tube of silicone will last forever in the fridge, too. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 PM |
