Use something similar to what George recommended. I used Weld-on brand. You want a solvent weld for acrylics. I went to the local glass shop and they gave me an opened tube for free. There are different viscosities and for a crack, you want a thin, watery version that you apply with a needle so it can seep into the crack. Mine was broken at the original glue joint. Here's the result.
I also repaired a crack using the needle method but don't have a pic. Worked great though. The trick is to clamp the pieces or crack together tight and then apply the solvent so it gets sucked into the crack by capillary action. The perfect amount fills the area without any excess. Too much, and the solvent melts whatever it touches to leave a visible blemish. Too little and you have voids that will be visible. A good repair is invisible or close to it.
