How do you separate this wire connector?, I need to remove and test this fan. |
dgraves |
Oct 7 2018, 05:00 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
Sorry for the poor (dark) photo. How do you go about separating this wire connector? I think my heater fan might need rebuilding.
Attached thumbnail(s) |
JeffBowlsby |
Oct 7 2018, 05:02 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Just pull the wires out. The wires will come undone at one or both ends. Dont pull so hard that they break.
North Coast Jim |
Oct 7 2018, 05:53 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
rgalla9146 |
Oct 7 2018, 06:05 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
the two wires closest to the motor are attached to the plastic piece
the two away from the motor will pull out. |
Rob-O |
Oct 7 2018, 08:30 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Before you pull the motor, why do you think it needs replacing? If it’s just not working I’d start with the control in the passenger compartment if you haven’t already. The wires fall off and they also corrode to the point that it won’t turn the fan on.
Oct 7 2018, 08:46 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Dynamite. That will separate the wires!
Oh, you mean separate from each other, not all of the tiny pieces of the car, and in a way that they can be re-connected? Yeah, just do what Jeff said. --DD |
theer |
Oct 8 2018, 05:59 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
After you pull one or both wires out of its connector (probability in the high 90% range), use long needle nose pliers to extract the connector.
simonjb |
Oct 8 2018, 05:45 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
You can buy replacement connectors if needed. Bughaus
Lo-Fi Version | Time is now: 13th May 2024 - 11:20 AM |
