Back shocks/springs? |
PatrickB |
Oct 9 2018, 03:36 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Probably been covered a bunch of times, but..
I think I'm due. pretty sure I've got a spring getting weak on one side, and don't like the way the spring perches are held in place on the current setup... so I'm looking for something else. Would like a fairly solid spring rate. Also want adjustable perches. We autocross the car. On the off chance someone here in Ontario has something used on the shelf I'm willing to go for a short drive, but I'm looking for something decent that will do what I want. Not specifically looking for used but if there's something decent available and I can save a few bucks it doesn't bother me. Any suggestions? |
Oct 9 2018, 05:39 AM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rebel Racing has what you need. Prices are fair.
dr914@autoatlanta.com |
Oct 9 2018, 09:18 AM
914 Guru Group: Members Posts: 7,846 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you could use bilstein with 914-6 factory springs to get more oversteer for autocross
Probably been covered a bunch of times, but.. I think I'm due. pretty sure I've got a spring getting weak on one side, and don't like the way the spring perches are held in place on the current setup... so I'm looking for something else. Would like a fairly solid spring rate. Also want adjustable perches. We autocross the car. On the off chance someone here in Ontario has something used on the shelf I'm willing to go for a short drive, but I'm looking for something decent that will do what I want. Not specifically looking for used but if there's something decent available and I can save a few bucks it doesn't bother me. Any suggestions? |
PatrickB |
Oct 9 2018, 03:09 PM
you could use bilstein with 914-6 factory springs to get more oversteer for autocross Probably been covered a bunch of times, but.. I think I'm due. pretty sure I've got a spring getting weak on one side, and don't like the way the spring perches are held in place on the current setup... so I'm looking for something else. Would like a fairly solid spring rate. Also want adjustable perches. We autocross the car. On the off chance someone here in Ontario has something used on the shelf I'm willing to go for a short drive, but I'm looking for something decent that will do what I want. Not specifically looking for used but if there's something decent available and I can save a few bucks it doesn't bother me. Any suggestions? Might not be a bad plan, car tends to understeer. Diesel did help with that though. More torque. |
Lo-Fi Version | Time is now: 11th May 2024 - 06:12 AM |
