'75-'76 under gas tank fuel filter bracket, what is it supposed to look like? |
carl k |
Oct 12 2018, 12:16 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
This is the best image I could find here on World of what I think is the fuel filter holder on a 1975. What is the correct shape of this bracket?
Is a square fuel filter supposed to clip into it, like the bracket I had below the engine shelf in my '74? Even if it was straight, it looks like the "arms" are too short. Or does the square filter go under the "arms" and get held against the opposite sheet metal? thanks, Carl |
914werke |
Oct 12 2018, 12:22 PM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yup that is correct. Uses the late style sqr filter with diff. size inlet & outlet.
carl k |
Oct 12 2018, 12:32 PM
TheCabinetmaker |
Oct 12 2018, 12:47 PM
Yes it does, but gonna be hard to do with that plumbing. The filter needs to be in the front of the pump. Are those ethanol and hi pressure lines? That elbow on the fittings looks too high. Have you test fitted the tank?
914werke |
Oct 12 2018, 12:56 PM
carl k |
Oct 12 2018, 01:06 PM
Hi guys-
Thanks for all the replies. The picture is not my setup, just one I found on another 914World post. I will upload a picture of what I've got this afternoon. I'm trying to go back to stock (car came with carbs and a Facet pump with generic inline filter). Carl |
Chris914n6 |
Oct 12 2018, 01:52 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
That mount is supposed to be straight and perpendicular. The square filter has a flange that slides inbetween and sort of locks into place. Sits under.
jim912928 |
Oct 12 2018, 04:38 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Just as an FYI...that setup is mine, fit's fine and it's for a 3.2L converted car i finished about 6 years ago. It's a 911 fuel pump with a course filter in front of the pump and a fine filter in the engine compartment.
carl k |
Oct 12 2018, 06:44 PM
bigkensteele |
Oct 12 2018, 07:43 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
914Sixer |
Oct 13 2018, 05:34 AM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
That is a standard Bosch filter, the ones they sell now DO NOT have locking ridge. I guess its to expensive to make them correctly.
Lo-Fi Version | Time is now: 9th May 2024 - 09:37 PM |
