73 filler neck gasket...1 or 2? |
914xr75 |
Oct 14 2018, 02:28 PM
Member Group: Members Posts: 174 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
76-914 |
Oct 14 2018, 02:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
one (IMG:style_emoticons/default/beerchug.gif)
914xr75 |
Oct 14 2018, 03:47 PM
Perfect. Thanks 76 914
mepstein |
Oct 14 2018, 05:14 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Also replace the gasket in the cap and under the fuel sender.
rhodyguy |
Oct 14 2018, 05:45 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Has all of the evaporation system been removed? The small pipe is open to the atmosphere. It would connect to the plastic plenum that is missing. You're running carbs?
914xr75 |
Oct 14 2018, 11:13 PM
Yes. Running carbs.
porschetub |
Oct 15 2018, 12:22 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Ones good,welcome to the stinky carb car club ,no way you can get rid of all the fuel smell but a tank sender reseal and good fuel cap seal really help ,cheers.
maf914 |
Oct 15 2018, 05:15 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
The ring of bolts that holds the filler to the tank can be hard to access, at least they are on my 76. The bolt heads are very close to the molded plastic filler neck and require a thin wall socket. Make sure to tighten them all equally.
bdstone914 |
Oct 15 2018, 05:26 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If the leak is from the filler neck you shoul see some stains around the tank in that area.
That tank should have a metal expansion tank and has a visible metal filler neck. Only the 75-76 tanks had a one piece plastic expansion and filler neck. You will smell gas fumes unless you replace the evap system. You are missing the expansion tank, charcoal canister with hold down clamp and all the hoses that go with them. You can reinstall the evap system with carbs. If you decide to replace the system I have the parts. You would need new hoses. Bruce |
Lo-Fi Version | Time is now: 5th May 2024 - 02:18 AM |
