Self loosening axle bolts-will spring waters take care of this? |
Tdskip |
Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts. Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them? Thanks in advance for the help, have a good morning. |
SirAndy |
Oct 15 2018, 07:57 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That bolt doesn't look right, also, the center part of the threads is stripped ...
(IMG:style_emoticons/default/unsure.gif) |
Mark Henry |
Oct 15 2018, 08:06 PM
That bolt doesn't look right, also, the center part of the threads is stripped ... (IMG:style_emoticons/default/unsure.gif) Flattened, likely from banging against the loose CV. Factory bolts /4 are only threaded part way, 8mm tri-square female. schnorr washers are thin wavy washers with teeth ridges. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:55 AM |
