Self loosening axle bolts-will spring waters take care of this? |
Tdskip |
Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts. Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them? Thanks in advance for the help, have a good morning. |
Mikey914 |
Oct 15 2018, 10:06 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep
https://shop.914rubber.com/914-CV-bolt-dril...m?categoryId=-1 Got the wire and tool if you need it. Also just the Schorr washers .20 each https://shop.914rubber.com/Schnorr-washers-...-part-SCHM8.htm |
burton73 |
Oct 16 2018, 09:44 AM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Yep https://shop.914rubber.com/914-CV-bolt-dril...m?categoryId=-1 Got the wire and tool if you need it. Also just the Schorr washers .20 each https://shop.914rubber.com/Schnorr-washers-...-part-SCHM8.htm Just get these from 914rubber and be done. Bob B |
Lo-Fi Version | Time is now: 9th May 2024 - 02:19 PM |
