Self loosening axle bolts-will spring waters take care of this? |
Tdskip |
Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts. Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them? Thanks in advance for the help, have a good morning. |
pete000 |
Oct 15 2018, 10:18 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps !
What is the torque spec for the CV bolts? |
RenoRoger |
Oct 16 2018, 03:21 AM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps ! What is the torque spec for the CV bolts? Haynes says 31lbs, others say 25 lbs |
porschetub |
Oct 16 2018, 01:10 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps ! What is the torque spec for the CV bolts? Haynes says 31lbs, others say 25 lbs Do mine @ 30lbs seem to remember Eric @ PMB stated something like that,the bolts are strong enough to take it and yes make sure they and clean and inspect the threads and bin any damaged ones. |
Lo-Fi Version | Time is now: 10th May 2024 - 03:40 PM |
