1973-914 2.0 compression issues., 914 2.0 rebuild suggestions |
9144me2enjoy |
Oct 15 2018, 08:54 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I’ve a 73-914 With a the original 2.0L Fuel Injection engine. Has about 75k miles. Set for about 10 years, brought back to life about 6 months ago. Checked compression and got readings of 90-95 psi across all 4 cylinders. Engine seams to run pretty good with that compression. Doesn’t seam to smoke any while driving but some bluish smoke when you first start it up. Pulls good up to redline. I was hoping to get the compression up to a range of 135-150 psi. Without spending a lot of money, what would you recommend to improve the compression? Valve job, new rings? Who would you recommend to do the work in the area? Estimated cost, Located in Oregon. Thanks
Mblizzard |
Oct 15 2018, 09:02 AM
Ok just confirm the compression check was completed with the engine warm and throttle wide open.
Best place to start is with a leak down test. That will tell you where you are losing compression through the valve or past the rings. Realistically if you are going to pay to have the engine pulled to do a valve job then I would count on putting in new rings as a minimum. I do all my work myself so I cant help on the pricing. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:17 AM |
