1973-914 2.0 compression issues., 914 2.0 rebuild suggestions |
9144me2enjoy |
Oct 15 2018, 08:54 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I’ve a 73-914 With a the original 2.0L Fuel Injection engine. Has about 75k miles. Set for about 10 years, brought back to life about 6 months ago. Checked compression and got readings of 90-95 psi across all 4 cylinders. Engine seams to run pretty good with that compression. Doesn’t seam to smoke any while driving but some bluish smoke when you first start it up. Pulls good up to redline. I was hoping to get the compression up to a range of 135-150 psi. Without spending a lot of money, what would you recommend to improve the compression? Valve job, new rings? Who would you recommend to do the work in the area? Estimated cost, Located in Oregon. Thanks
9144me2enjoy |
Oct 15 2018, 01:06 PM
Re did the Comrpession test with engine warm and as described. Compression test bumped up to 105-115 across all cylinders. Then added some oil to the cylinders and the compression bumped up a little but not much 110-120 range. The valves were last adjusted about 10 years ago or probably about 200 miles ago. Working on a leak down test.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
