1973-914 2.0 compression issues., 914 2.0 rebuild suggestions |
9144me2enjoy |
Oct 15 2018, 08:54 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I’ve a 73-914 With a the original 2.0L Fuel Injection engine. Has about 75k miles. Set for about 10 years, brought back to life about 6 months ago. Checked compression and got readings of 90-95 psi across all 4 cylinders. Engine seams to run pretty good with that compression. Doesn’t seam to smoke any while driving but some bluish smoke when you first start it up. Pulls good up to redline. I was hoping to get the compression up to a range of 135-150 psi. Without spending a lot of money, what would you recommend to improve the compression? Valve job, new rings? Who would you recommend to do the work in the area? Estimated cost, Located in Oregon. Thanks
brant |
Oct 15 2018, 03:27 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
please adjust the valves
you are really only guessing if you haven't done that might as well just throw dollar bills out the window as you drive. I would NEVER even start a 10 year sitting motor without doing a valve adjustment... your motor is tired rebuild it or live with it I have lived with many tired motors it may even get better if you do a lot of work to bring the compression back on a tired motor, you are now most likely stressing the also tired bottom end... the results will likely be that you have now changed what is the weak link in your engine... often in these scenario's you have wasted money on the top end and get to respend it when you rebuild the bottom end.... |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:48 AM |
