1973-914 2.0 compression issues., 914 2.0 rebuild suggestions |
9144me2enjoy |
Oct 15 2018, 08:54 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I’ve a 73-914 With a the original 2.0L Fuel Injection engine. Has about 75k miles. Set for about 10 years, brought back to life about 6 months ago. Checked compression and got readings of 90-95 psi across all 4 cylinders. Engine seams to run pretty good with that compression. Doesn’t seam to smoke any while driving but some bluish smoke when you first start it up. Pulls good up to redline. I was hoping to get the compression up to a range of 135-150 psi. Without spending a lot of money, what would you recommend to improve the compression? Valve job, new rings? Who would you recommend to do the work in the area? Estimated cost, Located in Oregon. Thanks
9144me2enjoy |
Oct 15 2018, 07:55 PM
I agree with everyone’s comments. I plan on getting the valves checked/adjusted tomorrow and then I will drive it for a little bit and do another compression check. From my past experience over the years I realize if and when I do decide to rebuild the engine, there really isn’t any shortcuts! Do it right the first time and rebuild both the top end and the bottom end with good parts along with a machine shop that knows what there doing. Thanks again.
Lo-Fi Version | Time is now: 18th May 2024 - 07:13 AM |
