914 sighting, Wilmington junk yard |
abes914 |
Oct 16 2018, 05:41 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
Chi-town |
Oct 18 2018, 01:55 PM
I went out to see what was left and there's not much.
Interior is gone except seat shells and lower dash bolster that looked decent. There's a small block with a custom engine mounting plate but all the coolant accessories are gone and it has a 901 behind it. Top, Trunk, and hood are gone but the wide body kit is still all there. Doors are in decent shape. Rear glass and door glass is good. Engine lid still there. I took the targa latches and door check. Fuel tank is punctured at the top and full of rust, I took all the hold down / mounting hardware and outlet nipples and sender. Wiring is all chopped up. It's a re-drilled 5 lug with stock calipers. |
ValcoOscar |
Oct 18 2018, 02:41 PM
Garage Life Group: Members Posts: 2,384 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I went out to see what was left and there's not much. Interior is gone except seat shells and lower dash bolster that looked decent. There's a small block with a custom engine mounting plate but all the coolant accessories are gone and it has a 901 behind it. Top, Trunk, and hood are gone but the wide body kit is still all there. Doors are in decent shape. Rear glass and door glass is good. Engine lid still there. I took the targa latches and door check. Fuel tank is punctured at the top and full of rust, I took all the hold down / mounting hardware and outlet nipples and sender. Wiring is all chopped up. It's a re-drilled 5 lug with stock calipers. Did you grab front and rear trunk hinges (w hardware)???? (IMG:style_emoticons/default/idea.gif) Oscar |
Lo-Fi Version | Time is now: 12th May 2024 - 11:06 AM |
