OMG I screwed up..., Rear trunk stuck locked. |
HansJan |
Oct 18 2018, 11:29 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
I was considering making a new username for this (because it soo embarrassing). But we are almost like family on this site, and it would come out sooner or later.
After getting the car back from painting, I’m putting it back together. When reinstalling the rear trunk lock and latch-pin, I closed the trunk. Now it’s stuck closed. I’m able to push the lock in (like unlocking it), but it doesn’t release the latch-pin. The rear lights are installed, so I can’t reach in. Popping out the targa-latch cups, doesn’t help much (my head is too big to see inside). Now I’m thinking about unbolting the hinges from the car, which might allow me some wiggle room. But before doing so I like to see if any of you have better suggestions. Feel free to make fun of me (I deserve it), but helpful suggestions are most welcome. Ps: I’m using the hood shocks instead of springs. |
rhodyguy |
Oct 18 2018, 11:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Have you tried putting pressure on the lid while pressing the release?
HansJan |
Oct 18 2018, 11:43 AM
Oct 18 2018, 11:53 AM
Resident German Group: Admin Posts: 41,631 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The old ratchet + lots of extensions should do the trick. Best done with a helper.
- Pop the top latch cups and push them inside the trunk - Have a helper shine a flashlight trough one of the cup holes onto the rear latch assembly - Get a ratchet and add enough extensions to get you through the other cup hole all the way back to the rear latch. You may want to use a swivel extension at the end. - Undo the two bolts that hold the latch to the rear panel - Done (IMG:style_emoticons/default/smash.gif) |
rgalla9146 |
Oct 18 2018, 12:06 PM
Advanced Member Group: Members Posts: 4,551 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The old ratchet + lots of extensions should do the trick. Best done with a helper. - Pop the top latch cups and push them inside the trunk - Have a helper shine a flashlight trough one of the cup holes onto the rear latch assembly - Get a ratchet and add enough extensions to get you through the other cup hole all the way back to the rear latch. You may want to use a swivel extension at the end. - Undo the two bolts that hold the latch to the rear panel - Done (IMG:style_emoticons/default/smash.gif) Yep that's the way. (IMG:style_emoticons/default/agree.gif) Use 1/4" extensions and a 'wobble' extension at the socket end. |
Oct 18 2018, 12:41 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
BTDT. Works.
Dion |
Oct 18 2018, 01:17 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
The old ratchet + lots of extensions should do the trick. Best done with a helper. - Pop the top latch cups and push them inside the trunk - Have a helper shine a flashlight trough one of the cup holes onto the rear latch assembly - Get a ratchet and add enough extensions to get you through the other cup hole all the way back to the rear latch. You may want to use a swivel extension at the end. - Undo the two bolts that hold the latch to the rear panel - Done (IMG:style_emoticons/default/smash.gif) Yep that's the way. (IMG:style_emoticons/default/agree.gif) Use 1/4" extensions and a 'wobble' extension at the socket end. This is why this site is so great! |
76-914 |
Oct 18 2018, 01:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Then attach a small wire to the latch mechanism and route it behind the bumper. Next time it's just a tug on the wire. One time was enough for me. (IMG:style_emoticons/default/beerchug.gif)
ValcoOscar |
Oct 18 2018, 02:47 PM
Garage Life Group: Members Posts: 2,384 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
OH OH...Hey Bruce, @bdstone914 we may need to do this with Diane's car. I went to open rear trunk and same, button didn't release latch. Bring some 1/4" extensions Sunday...I have some but not enough. (IMG:style_emoticons/default/headbang.gif)
Oscar |
Olympic 914 |
Oct 18 2018, 02:49 PM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
TheCabinetmaker |
Oct 18 2018, 04:27 PM
After getting the car back from painting, I’m putting it back together. When reinstalling the rear trunk lock and latch-pin, I closed the trunk. Now it’s stuck closed. If you put the trunk latch in 180 out it will not unlock. the pin won't hit the release. Nailed it! |
worn |
Oct 18 2018, 04:48 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Use the extensions. When I did this I was more than a thousand miles from home with the manual locked in the trunk. Cost $300 a night to stay in Yellowstone. Wife slept while I ratchet. You know what? I had taken the precaution of looking at this site.
So the extensions will work. I suspect you will have to use a lot of padding to protect your paint. |
HansJan |
Oct 18 2018, 09:05 PM
Thanks every one.
I was able to remove the bulkhead seal and wiggle the extensions through the gap there. From here the reach is better (straight shot) and I could actually see, since I was never able to get a good look through the latch-cup holes. It’s open.... Afterwards I broke the pin from the lock (need to buy a new one). Pretty happy. |
HansJan |
Oct 18 2018, 09:53 PM
QUOTE It’s open.... Afterwards I broke the pin from the lock (need to buy a new one). Pretty happy. Any one selling the little piece with the pin (that pushes the latch open)? It screws on to the back of the lock. 914Rubber nor Pelican have it. |
JFG |
Oct 19 2018, 04:00 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
glad you got it open in the end.
i was dreading this so sorted mine before the lights went in. my pin was bent and only a small part of it was contacting the mechanism. i stuck a small piece of aluminium tube over the pin to widen the surface area to minimise the risk of this in the future. |
Oct 19 2018, 04:17 AM
QUOTE It’s open.... Afterwards I broke the pin from the lock (need to buy a new one). Pretty happy. Any one selling the little piece with the pin (that pushes the latch open)? It screws on to the back of the lock. 914Rubber nor Pelican have it. Tweet / Dan has them. |
Olympic 914 |
Oct 19 2018, 06:19 AM
I broke the pin from the lock (need to buy a new one). I bought one from Auto Atlanta. its plastic but does work, the pin was a little long and required some filing to fit and work right. check it first. I was concerned about it being plastic instead of pot metal like the original, but it has been working fine. |
Lo-Fi Version | Time is now: 11th May 2024 - 11:07 PM |
