I dropped a wrench down a hole -- anyone know how to get it out? |
Charles Danek |
Oct 18 2018, 04:47 PM
Newbie Group: Members Posts: 35 Joined: 8-February 15 From: United States Member No.: 18,409 Region Association: Southern California |
I was trying to remove what I believe to be the speaker brackets from my 914. But the bolts just kept spinning with nothing to secure the studs on the other side. So I snuck a 10mm wrench through the hole pictured -- which I promptly dropped.
Now the wrench is stuck down there. I tried fishing it out with a magnet for a while, but without success. Does anyone know if there is a way to access this area? Or have any other advice as to how to retrieve it? Thanks in advance -- (IMG:style_emoticons/default/sad.gif) The wrench went down that hole. v v v (IMG:http://www.914world.com/bbs2/uploads_offsite/photos.smugmug.com-18409-1539902870.1.jpg) |
JeffBowlsby |
Oct 18 2018, 04:49 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Telescoping rod with a magnet. Any flaps or even home center has them.
worn |
Oct 18 2018, 04:51 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
worn |
Oct 18 2018, 04:53 PM
Telescoping rod with a magnet. Any flaps or even home center has them. Magnet ought to work. What is the strapping steel in the photo? A mirror on a stick would help you find out why the magnet isn’t working. Good luck, we are all pulling for you. |
JSA |
Oct 18 2018, 06:26 PM
Newbie Group: Members Posts: 9 Joined: 2-October 18 From: Osawatomie,Ks. Member No.: 22,538 Region Association: None |
Borescope can be a lifesaver.Used mine for lots of lost nuts and bolts.
https://www.amazon.com/Wallfire-Semi-rigid-...words=borescope |
914forme |
Oct 18 2018, 07:06 PM
To get it out, you need to find it. A borescope with a magnet will help your search and rescue the wrench. Learn from this and tie a string to the wrench the next time. If you ever worked on water, high in the air or other places you don't wish to have to go to retrieve a dropped tool, string or rope is your friend. |
Valy |
Oct 18 2018, 08:37 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Just turn it upside down and shake a bit. The wrench will come out.
steuspeed |
Oct 18 2018, 08:58 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Strip some romex home electrical wire 14/2 wrap one end of the bare wire around a high power magnet. Wrap that with some electrical tape so the magnet cannot get away and stick down in the unibody. Fish the flexible copper wire down in the hole. Good luck!
Chris914n6 |
Oct 18 2018, 09:38 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Mine is older and doesn't have the magnets, but I use one of these often.
24 in. 2-in-1 Magnetic Pickup Tool Also a small mirror to see it. Telescoping Mirror |
Spoke |
Oct 18 2018, 11:27 PM
If I did that on my rust bucket 914 the wrench would be lying on the floor. (IMG:style_emoticons/default/beerchug.gif)
JFG |
Oct 19 2018, 03:52 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
that's a tiny hole to try to recover your spanner from. chances are if you can find it and you can hook it, you'll drop it at the hole again. i hope i'm wrong and you do find it and get it out.
but, is that effort really worth a 10mm spanner? i'd leave it in there and spray a whole load of cavity wax inside to stop it rattling (and rust proof that joint) or, i would cut a hole in the long and get it out that way (last resort) |
mlindner |
Oct 19 2018, 05:15 AM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
With a mirror, first get it unstuck with a coat hanger.....when loose then try magnet. Best, Mark
mbseto |
Oct 19 2018, 08:17 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Your wrench cannot have gone far, it should be sitting just under that hole in the wedge-shaped door pillar base. You should be able to see it easily with a mirror.
But here's the most efficient solution: Get a kid in the neighborhood and dangle a 10-spot in front of him/her. Say there's a wrench down there and if you get it out for me, the 10 is yours. You might want to stipulate, no cutting. |
Jamie |
Oct 19 2018, 08:49 AM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
The shop monkey is never around when we need him most!
maf914 |
Oct 19 2018, 08:50 AM
Learn from this and tie a string to the wrench the next time. If you ever worked on water, high in the air or other places you don't wish to have to go to retrieve a dropped tool, string or rope is your friend. I once found a big 15" adjustable crescent wrench while scuba diving off a former US Navy pier in Key West, FL. I assume the mechanic did not tether the wrench. It was scummy and a bit corroded, but it cleaned up nicely and now resides in my tool box. And it has come in handy a few times. |
Charles Danek |
Oct 19 2018, 10:37 AM
"Just turn it upside down and shake a bit. The wrench will come out."
(IMG:style_emoticons/default/laugh.gif) Thanks for all the suggestions -- lots of things to try -- I will let you know how it goes! |
Chip |
Oct 21 2018, 05:23 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Rent-A-Ferret.
BeemerSteve |
Oct 21 2018, 06:36 PM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Skil saw! (IMG:style_emoticons/default/aktion035.gif)
wndsrfr |
Oct 21 2018, 08:41 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Leave it there already....move along, nothing to see here folks...
MikeSpraggi |
Oct 21 2018, 09:17 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 17th May 2024 - 12:45 PM |
