Charles Danek
Oct 18 2018, 04:47 PM
I was trying to remove what I believe to be the speaker brackets from my 914. But the bolts just kept spinning with nothing to secure the studs on the other side. So I snuck a 10mm wrench through the hole pictured -- which I promptly dropped.
Now the wrench is stuck down there. I tried fishing it out with a magnet for a while, but without success.
Does anyone know if there is a way to access this area? Or have any other advice as to how to retrieve it?
Thanks in advance --
The wrench went down that hole.
v
v
v
JeffBowlsby
Oct 18 2018, 04:49 PM
Telescoping rod with a magnet. Any flaps or even home center has them.
worn
Oct 18 2018, 04:51 PM
QUOTE(JeffBowlsby @ Oct 18 2018, 03:49 PM)
Magnet ought to work. What is the strapping steel in the photo?
worn
Oct 18 2018, 04:53 PM
QUOTE(worn @ Oct 18 2018, 03:51 PM)
A mirror on a stick would help you find out why the magnet isn’t working. Good luck, we are all pulling for you.
JSA
Oct 18 2018, 06:26 PM
Borescope can be a lifesaver.Used mine for lots of lost nuts and bolts.
https://www.amazon.com/Wallfire-Semi-rigid-...words=borescope
914forme
Oct 18 2018, 07:06 PM
To get it out, you need to find it. A borescope with a magnet will help your search and rescue the wrench.
Learn from this and tie a string to the wrench the next time. If you ever worked on water, high in the air or other places you don't wish to have to go to retrieve a dropped tool, string or rope is your friend.
Valy
Oct 18 2018, 08:37 PM
Just turn it upside down and shake a bit. The wrench will come out.
steuspeed
Oct 18 2018, 08:58 PM
Strip some romex home electrical wire 14/2 wrap one end of the bare wire around a high power magnet. Wrap that with some electrical tape so the magnet cannot get away and stick down in the unibody. Fish the flexible copper wire down in the hole. Good luck!
Chris914n6
Oct 18 2018, 09:38 PM
Mine is older and doesn't have the magnets, but I use one of these often.
24 in. 2-in-1 Magnetic Pickup ToolAlso a small mirror to see it.
Telescoping Mirror
Spoke
Oct 18 2018, 11:27 PM
If I did that on my rust bucket 914 the wrench would be lying on the floor.
JFG
Oct 19 2018, 03:52 AM
that's a tiny hole to try to recover your spanner from. chances are if you can find it and you can hook it, you'll drop it at the hole again. i hope i'm wrong and you do find it and get it out.
but, is that effort really worth a 10mm spanner? i'd leave it in there and spray a whole load of cavity wax inside to stop it rattling (and rust proof that joint)
or, i would cut a hole in the long and get it out that way (last resort)
mlindner
Oct 19 2018, 05:15 AM
With a mirror, first get it unstuck with a coat hanger.....when loose then try magnet. Best, Mark
mbseto
Oct 19 2018, 08:17 AM
Your wrench cannot have gone far, it should be sitting just under that hole in the wedge-shaped door pillar base. You should be able to see it easily with a mirror.
But here's the most efficient solution: Get a kid in the neighborhood and dangle a 10-spot in front of him/her. Say there's a wrench down there and if you get it out for me, the 10 is yours. You might want to stipulate, no cutting.
Jamie
Oct 19 2018, 08:49 AM
The shop monkey is never around when we need him most!
maf914
Oct 19 2018, 08:50 AM
QUOTE(914forme @ Oct 18 2018, 05:06 PM)
I once found a big 15" adjustable crescent wrench while scuba diving off a former US Navy pier in Key West, FL. I assume the mechanic did not tether the wrench. It was scummy and a bit corroded, but it cleaned up nicely and now resides in my tool box. And it has come in handy a few times.
Charles Danek
Oct 19 2018, 10:37 AM
"Just turn it upside down and shake a bit. The wrench will come out."
Thanks for all the suggestions -- lots of things to try -- I will let you know how it goes!
Chip
Oct 21 2018, 05:23 PM
Rent-A-Ferret.
BeemerSteve
Oct 21 2018, 06:36 PM
Skil saw!
wndsrfr
Oct 21 2018, 08:41 PM
Leave it there already....move along, nothing to see here folks...
MikeSpraggi
Oct 21 2018, 09:17 PM
QUOTE(wndsrfr @ Oct 21 2018, 07:41 PM)
Didja get it?
whitetwinturbo
Nov 3 2018, 12:03 AM
C5 will open the hole a bit
