What Motor and Transmission mounts to use, What motor and transmission mounts to use |
Ken Mikos |
Oct 28 2018, 07:32 PM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
Replacing motor and transmission mounts in a original 1973 1.7. Any suggestion on the type and where to purchase? Thanks,
Ken |
Literati914 |
Oct 31 2018, 06:09 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
*Modified 911 mounts do not have the proper anti-rotation pins on the center sleeve, .. not quite the correct thickness, are not the correct stiffness, do not have an original appearance, and require the mounting holes in the ears to be re-drilled. However, modified 911 mounts were a functional substitute until the correct 914 mounts were finally available again. So, are you saying that either of the engine mounts that you posted above, could be used for the 914 Transmission? and that they are better options than the 911 motor mount, one (like DRPHIL914 posted a picture of above)? here is a picture of a 911 motor mount used on the 914 transmission and stock washers ..and DRPHIL914, did you have to make the multiple modification outlined by UROpartsman to this particular 911 ENGINE mount (that you've used at the 914 transmission)? Is there a 911 mount that works at the transmission (of 914) that does not need modifications. Or is the 914/6 motor mount a better option for tranmission mounts. Sorry but I'm obviously confused. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 09:45 PM |
