What Motor and Transmission mounts to use, What motor and transmission mounts to use |
Ken Mikos |
Oct 28 2018, 07:32 PM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
Replacing motor and transmission mounts in a original 1973 1.7. Any suggestion on the type and where to purchase? Thanks,
Ken |
Literati914 |
Oct 31 2018, 07:49 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I think either the 914-6, 911, or WEVO mounts will work great for you. I f8nd that minimizing deflection at the transmission mounts does seem to help with shifting. Ok good, but they'll need to be modified or not (IMG:style_emoticons/default/confused24.gif) |
DRPHIL914 |
Oct 31 2018, 08:03 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I think either the 914-6, 911, or WEVO mounts will work great for you. I f8nd that minimizing deflection at the transmission mounts does seem to help with shifting. Ok good, but they'll need to be modified or not (IMG:style_emoticons/default/confused24.gif) When i purchased my 911 mounts they were the only option , but the only modification made was slightly enlarge the holes in the ear of the mounts easy peasy and you can see from my pictures after 6/7 years they look and work like new, still nice and tight, no extra movement, very tight. Back then URO had not stepped up and made a solid reproduction of the original mount. The 911 mounts will work just fine, but i would not heaitate to test out that 914/6 reproductuon from URO. Drew will stand behind the product i am sure if its not up to your satisfaction |
Lo-Fi Version | Time is now: 16th May 2024 - 03:04 AM |
