Value of a 7R case? |
sixnotfour |
Nov 11 2018, 02:40 AM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I just sent them a numbers matching -6 case..to weld up a spun main ...$2900
Nov 11 2018, 05:57 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
porschetub |
Nov 11 2018, 11:41 PM
Does the 2.4T have the noncounterweighted crank like the 2.2T? If so, did you replace your crank? I have a 2.2T that is destined for one of my 914s, rebuilt to a 2.5E or S spec, but damn, cranks are expensive these days!! My engine is an early 2.4T Euro case, built to S specs. Lots of fun! http://www.914world.com/bbs2/style_images/...ages/indent.gif Nothing wrong with crankshafts from the 2.2 just folks being dictated by what they read on the net. Top engine builders are using them (66mm) with larger bores to good result,check to see whats happening @ Supertec think the 2.4 was the first to use the larger throw crank as far as I remember but could be wrong . |
stownsen914 |
Nov 13 2018, 12:43 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I've been reading about the aftermarket 911 cases over on Pelican - one guy is doing a cast version and another guy is now in the mix doing billet early cases. No one has mentioned cost yet. Not cheap, I'm sure. I'm guessing $10-20K? Anyone know?
Nov 13 2018, 01:16 PM
I've been reading about the aftermarket 911 cases over on Pelican - one guy is doing a cast version and another guy is now in the mix doing billet early cases. No one has mentioned cost yet. Not cheap, I'm sure. I'm guessing $10-20K? Anyone know? Catorze is a world member doing the 3.6 case. I think he is shooting for $5K. |
stownsen914 |
Nov 13 2018, 01:36 PM
Nov 13 2018, 01:49 PM
Catorze is a world member doing the 3.6 case. I think he is shooting for $5K. That's actually not bad if it's really ready to go at that price. It's easy to drop $3-4K between purchasing a 911 case and then having all the work done to make it go to go. (IMG:style_emoticons/default/agree.gif) Once there is a good supply of cases, I believe there will be more aftermarket manufacturers of parts to complete the engines. |
Wegeng_Haus |
Dec 7 2018, 08:57 AM
Newbie Group: Members Posts: 38 Joined: 10-December 11 From: Champaign Illinois Member No.: 13,881 Region Association: Upper MidWest |
So now that you have multiple opinions is the case for sale or is it going to be used for art (IMG:style_emoticons/default/confused24.gif) Breaking news: I checked the case serial number with factory records and it is a 1975, 2.7 "S" case, also the same specs as a '75 USA Carrera. I'm still not sure what to do with this thing. All opinions welcome. |
Mark Henry |
Dec 7 2018, 03:43 PM
So now that you have multiple opinions is the case for sale or is it going to be used for art (IMG:style_emoticons/default/confused24.gif) Breaking news: I checked the case serial number with factory records and it is a 1975, 2.7 "S" case, also the same specs as a '75 USA Carrera. I'm still not sure what to do with this thing. All opinions welcome. IIRC 75-77 they are all "S" cases, nothing special. |
brant |
Dec 7 2018, 03:57 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
So now that you have multiple opinions is the case for sale or is it going to be used for art (IMG:style_emoticons/default/confused24.gif) Breaking news: I checked the case serial number with factory records and it is a 1975, 2.7 "S" case, also the same specs as a '75 USA Carrera. I'm still not sure what to do with this thing. All opinions welcome. IIRC 75-77 they are all "S" cases, nothing special. I believe the 1975's were all thermal reactor cars in the US. And the cases from that year were considered the least desirable as they have all been thermally stressed by the reactors. |
Dec 7 2018, 04:14 PM
So now that you have multiple opinions is the case for sale or is it going to be used for art (IMG:style_emoticons/default/confused24.gif) Breaking news: I checked the case serial number with factory records and it is a 1975, 2.7 "S" case, also the same specs as a '75 USA Carrera. I'm still not sure what to do with this thing. All opinions welcome. IIRC 75-77 they are all "S" cases, nothing special. I believe the 1975's were all thermal reactor cars in the US. And the cases from that year were considered the least desirable as they have all been thermally stressed by the reactors. yep. And mag only gets more brittle as it ages. Too bad you aren't talking 3.0 Euro Carrera case |
Larmo63 |
Dec 7 2018, 08:24 PM
I'd put it up for $2500 FIRM as it sits on 911S Registry.
Don't put any more machine work money into it. (You really don't need to) My $.02 |
GeorgeRud |
Dec 7 2018, 10:05 PM
I’d also recommend putting it on the Pelican Parts Classified Forum for the best chance of finding a buyer. Otherwise, eBay or Bring A Trailer might be other options.
Mark Henry |
Dec 7 2018, 10:13 PM
$2000, knock another $500 off that if you want a quicker sale.
https://www.google.ca/search?ei=kkMLXO3sK8W...i30.WxAX4WOol0U |
Dec 8 2018, 07:39 AM
$2000, knock another $500 off that if you want a quicker sale. https://www.google.ca/search?ei=kkMLXO3sK8W...i30.WxAX4WOol0U (IMG:style_emoticons/default/agree.gif) there’s lots of pie in the sky asking prices but unless someone mess a specific case, mag cases just aren’t worth big money. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:22 AM |
