First clutch job, How does my old one look |
ericoneal |
Nov 1 2018, 06:42 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
Just put a new clutch on to try to remedy the rattling I've been hearing when I press on the pedal. Already repaced the throwout bearing last year with no luck, so now I'm doing the whole she-bang:
The Noise My old clutch says "Sachs" on it, but the disk says "Made in Germany" and has four springs vs. six. Original? (Surely not) Do you guys see anything glaringly obvious that I may be missing? All of the springs seem tight. |
mgphoto |
Nov 1 2018, 06:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Looks a bit greasy, check the seals, engine and tranny.
Don’t forget to put a bit of grease in the pilot bearing, very light smear on the fingers that contact the throughout bearing also. You might swap out the plastic bushing in the throughout bearing arm, or just some grease there. The rivet depth is important, closer they get to the surface more of a chance they will contact the pressure plate or flywheel, that means resurfacing and another washer behind the ball pivot. Your doing fine. |
mgphoto |
Nov 1 2018, 06:57 PM
6 spring is 911S clutch disk, 4 spring is standard type IV, both fit.
mgphoto |
Nov 1 2018, 07:00 PM
Rattle can be caused by lose rivets on the pressure plate, can only be checked when pressure is applied to the fingers.
Mark Henry |
Nov 1 2018, 07:55 PM
4 spring has't been made for a long while, IIRC you can only get the 6 spring.
The 4 spring isn't as strong as the 6 and has spring to FW bolt clearance issues when you grind the flywheel. |
ericoneal |
Nov 1 2018, 08:10 PM
porschetub |
Nov 1 2018, 08:56 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Old plate? I suspect regardless of friction material left appears the springs may be loose in the disk,hence the rattling,how tight are the springs ???.
6 spring is standard for 911 ,nothing to do with 911S,4 spring is fine for a 914 but the six spring is apparently better. Don't muck around do everything as required (and mentioned) and you will be good for a long time. (IMG:style_emoticons/default/beer.gif) . |
Lo-Fi Version | Time is now: 20th May 2024 - 05:25 PM |
