cap and rotor, just want the right one.... |
brant |
Nov 2 2018, 03:01 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I would recommend you not take the distributor out.
its not that hard. but also can be reinstalled incorrectly and effect timing definitely will have to be re-timed at a minimum if you pull it best not to pull it the part number is on the body of the distributor google images might help with an example. |
mobymutt |
Nov 2 2018, 04:05 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
bbrock |
Nov 2 2018, 04:47 PM
A super simple thing to do without pulling the dizzy is to look for the connector for the trigger points. If it has a harness plugged into a connector like the black socket at the top of the dizzy in this pic, then it is a stock dizzy. Carb dizzies won't have that connector. Note also this dizzy is fitted with a non-rev limiting rotor like what you have now.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-20845-1541198848.1.jpg) |
Lo-Fi Version | Time is now: 7th June 2024 - 06:13 PM |
