PMB and excellent support, That pesky 13mm nut to loosen on rear calipers |
eyecolor |
Nov 3 2018, 08:30 AM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
First of all, a thank you to PMB for providing me some small parts for my rear calipers at no charge after re-building them over 5 years ago. Promise to make it up to you.
In trying to install the spring to my E brake I saw a pin was broken off. Searching this forum I saw an article on how to drill it out and replace it with the same bit used in the process. Worked beautiful. Artcle written by none other than Eric Shea of PMB! My issue is now the 13mm nut that you must loosen to adjust the 4mm hex screw to move the outer pad, jusr will not retighten. Any thoughts !!!! Thanks so much George Ozer Wilmington,DE |
mgphoto |
Nov 3 2018, 04:08 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Use an allen key to hold the adjuster, 13 mm socket held with a vice grips, hold the allan key tightly through the square ratchet hole and tighten the nut.
eyecolor |
Nov 5 2018, 06:38 PM
Nov 5 2018, 06:48 PM
Use an allen key to hold the adjuster, 13 mm socket held with a vice grips, hold the allan key tightly through the square ratchet hole and tighten the nut. You were 100% correct. Thank you!! I think he shows a picture of his “special” tool described above in his video. Glad it worked out. Let me know if there is anything you might need. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:13 AM |
