Front suspension, What do I have here? |
BiG bOgGs |
Nov 3 2018, 10:49 AM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
BiG bOgGs |
BiG bOgGs |
Nov 3 2018, 10:50 AM
Mark Henry |
Nov 3 2018, 10:57 AM
Likely 911T, looks like M calipers. Measure the caliper mount bolt spacing, if 3" I'm correct.
If it's 3.5" it's later 911. I have the 914/6 (same as 911T) struts, 3" spacing with the Alfa brembo Al calipers. |
BiG bOgGs |
Nov 3 2018, 11:06 AM
Thanks, I’ll check that. Does it look like it was a full front end swap, or does it look like they used the stock 914 torsion bars with just the struts and brakes swapped?
rhodyguy |
Nov 3 2018, 11:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are the hubs and the vented rotor one piece? I can't make out a parting line in the pictures.
BiG bOgGs |
Nov 3 2018, 11:32 AM
I believe they separate.
horizontally-opposed |
Nov 3 2018, 11:35 AM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Likely 911T, looks like M calipers. Measure the caliper mount bolt spacing, if 3" I'm correct. If it's 3.5" it's later 911. I have the 914/6 (same as 911T) struts, 3" spacing with the Alfa brembo Al calipers. (IMG:style_emoticons/default/agree.gif) And, oddly enough, have the same calipers as Mark. Ran M calipers for years before that. They're certainly capable of slowing a 914 down. |
Chi-town |
Nov 3 2018, 12:28 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Take the torsion adjusters off and count the splines, it'll tell you if they're 911 or 914.
Look at the ball joint retainer and see if it's a pinch bolt or wedge pin. (Bolt head or nut with washer) |
Mark Henry |
Nov 3 2018, 12:36 PM
Clean up the side of the strut tube, the part # should be there.
Nov 3 2018, 12:37 PM
914 crossmember
Lo-Fi Version | Time is now: 26th April 2024 - 08:05 AM |
