Case Question, Don't Recall this being stock |
Mblizzard |
Nov 5 2018, 11:33 AM
Getting ready to send my case out for some work and noticed these dowels on all of the case through bolts.
Been a while since I split a case but I don't think these are stock and there is no room for the stock little plastic vibration dampers that go on the bolts. Anyone seen this before? |
Chi-town |
Nov 5 2018, 12:55 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I've seen that with race prepped cases to prevent shift under hard use.
porschetub |
Nov 5 2018, 01:16 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Shuffle pins ,think that's the name ? ,not often used on a T4,worth while if you are pulling higher RPM.
Jetsetsurfshop |
Nov 5 2018, 01:19 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
WOW. Cool mod for sure.
Nov 5 2018, 01:30 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mblizzard |
Nov 5 2018, 01:44 PM
Had tis additional seal/bearing cover to keep the seal from moving at high rpm. |
90quattrocoupe |
Nov 5 2018, 03:23 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Mark Henry |
Nov 5 2018, 04:48 PM
Aluminum or biral cylinders and CB TB's. More than just shuffle pins.
Mblizzard |
Nov 5 2018, 06:03 PM
pilothyer |
Nov 5 2018, 06:37 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Aluminum or biral cylinders and CB TB's. More than just shuffle pins. Previous version of engine. Soon to be Nickies and such. Mike.....I am curious as to who you have trusted to do your case and crank and bearing work to ? Look forward to knowing your satisfaction with their work. Looks to be a nice build and wish you the best with it. Interested in what crank and rods you are using and which main bearings and rod bearings you will be using. The shuffle pins seem to be a good idea for higher RPM engines. I have built many succcessful T4 engines, but always looking for "cutting edge" mods. Thanks in advance for your reply. Jerry |
Jetsetsurfshop |
Nov 6 2018, 08:21 AM
Had tis additional seal/bearing cover to keep the seal from moving at high rpm. Find anymore mods? Who makes that induction? |
DRPHIL914 |
Nov 6 2018, 09:46 AM
almost a shame will all that set up, to take it apart and re-do it? that would have been nice as is for most of us... but this is Mike lol (IMG:style_emoticons/default/poke.gif) what was displacement and cam set up as it was before you tore into it?
Mblizzard |
Nov 6 2018, 10:37 AM
Had tis additional seal/bearing cover to keep the seal from moving at high rpm. Find anymore mods? Who makes that induction? That is a 44 mm CB Performance intake. |
Mblizzard |
Nov 6 2018, 10:40 AM
almost a shame will all that set up, to take it apart and re-do it? that would have been nice as is for most of us... but this is Mike lol (IMG:style_emoticons/default/poke.gif) what was displacement and cam set up as it was before you tore into it? Well with all the 'street cred" you earn from breaking a crank in a 2.3 going 20 mph in a school zone, I figured I needed to up my game a bit to recover. Only had a mild performance cam in it previously but the new one is a bit more aggressive. |
Mblizzard |
Nov 6 2018, 10:44 AM
Aluminum or biral cylinders and CB TB's. More than just shuffle pins. Previous version of engine. Soon to be Nickies and such. Mike.....I am curious as to who you have trusted to do your case and crank and bearing work to ? Look forward to knowing your satisfaction with their work. Looks to be a nice build and wish you the best with it. Interested in what crank and rods you are using and which main bearings and rod bearings you will be using. The shuffle pins seem to be a good idea for higher RPM engines. I have built many succcessful T4 engines, but always looking for "cutting edge" mods. Thanks in advance for your reply. Jerry Going to use Precision Machine Service (PMS), Pigeon Forge Tennessee. Talked with them on phone and went for a visit and was impressed. They are mainly "muscle car" guys but have the skills and drive to take on the odd jobs. Up front they never promised to be fast but it would be right. Only time will tell. Was a bit disappointed that many west coast shops I called or contacted never responded. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:51 PM |
