horn pad, 1971 |
horn pad, 1971 |
milwlandrover |
Nov 6 2018, 07:38 AM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Good morning guys,
On to my next project. I have no horn so I pulled off the pad and found no wires and the screws holding the "tabbed" ring are loose. I am going to order parts but want to be sure I get every thing I need. I will order the rubber return, I have a new contact, most likely the steering wheel contact ring. Do I need anything else? As always, thank you very much cheers! Attached image(s) |
Nov 6 2018, 08:29 AM
Brown wire from the steering wheel base to the (very) small metal tab on the metal ring of the horn pad. You don't need any additional parts on the horn pad.
dr914@autoatlanta.com |
Nov 6 2018, 09:51 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
your car uses a rubbing block on the steering column then on the butterfly a horn boot, and in the hole in the steering wheel a horn contact stalk to connect the pad to the rubbing block. That is all you need as long as the three pronged horn spring is not broken and well insulated and the three screws tight
Good morning guys, On to my next project. I have no horn so I pulled off the pad and found no wires and the screws holding the "tabbed" ring are loose. I am going to order parts but want to be sure I get every thing I need. I will order the rubber return, I have a new contact, most likely the steering wheel contact ring. Do I need anything else? As always, thank you very much cheers! |
Lo-Fi Version | Time is now: 17th May 2024 - 08:50 AM |
