New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Andyrew |
Nov 8 2018, 10:56 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I have a lot of thoughts on this subject (IMG:style_emoticons/default/smile.gif)
Bang for the big buck, easy, fast, reliable. LS motor with Boxster S trans. Easy bang for the buck. Fits right and sounds right Subaru 6 with Subaru trans. Turbo bang for the buck. Subaru turbo with Subaru trans. Those are all very conventional and fantastic swaps. Below are unconventional swaps. Honda v6. 901 trans. CHEAP, stupid reliable. I foresee this gaining popularity shortly. VW/Audi motor with Boxster trans. LOTS of fun and unconventional options here. You have to decide your goals for the car. Wiring is probably the most difficult part. I'm a self proclaimed expert on Audi motors and my favorite choices are as follows. With the fact that they we're all designed for similar bolt patterns on the transmission, the starter, and clutch assembly are all factory supported so it's much simpler. No adapter plates required, no mental mind games. See below for my thoughts on the VW/Audi motors V8 - ~300-350hp (plenty) good torque, high rev limit, exotic sound. Not enough torque to cause problems with some of the cheaper transmissions. 20v turbo 4. - cheap and reliable motor that has big support for big power depending on how much you spend. 200-900hp VR6 motor - same as above, but heavier. Many people turbo these for up to 4 digit numbers. As a bonus Porsche put these motors in the Cayenne so you can claim it's a Porsche motor if you get the right block. 20v turbo 5 - see 20v turbo 4. But more low end torque, more potential, and a longer engine. (Space becomes tight at this point) Something I'd like to do is a K20 with Honda trans. BIG turbo and all cheap Honda parts. Try for 500whp swap for less than 5k. I think if I tackle another car it's going to be either a really simple swap like Subaru 6 or Honda. Or a Audi V8 simply for the sound. |
mgp4591 |
Nov 8 2018, 01:28 PM
914 Guru Group: Members Posts: 5,375 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I have a lot of thoughts on this subject (IMG:style_emoticons/default/smile.gif) Bang for the big buck, easy, fast, reliable. LS motor with Boxster S trans. Easy bang for the buck. Fits right and sounds right Subaru 6 with Subaru trans. Turbo bang for the buck. Subaru turbo with Subaru trans. Those are all very conventional and fantastic swaps. Below are unconventional swaps. Honda v6. 901 trans. CHEAP, stupid reliable. I foresee this gaining popularity shortly. VW/Audi motor with Boxster trans. LOTS of fun and unconventional options here. You have to decide your goals for the car. Wiring is probably the most difficult part. I'm a self proclaimed expert on Audi motors and my favorite choices are as follows. With the fact that they we're all designed for similar bolt patterns on the transmission, the starter, and clutch assembly are all factory supported so it's much simpler. No adapter plates required, no mental mind games. See below for my thoughts on the VW/Audi motors V8 - ~300-350hp (plenty) good torque, high rev limit, exotic sound. Not enough torque to cause problems with some of the cheaper transmissions. 20v turbo 4. - cheap and reliable motor that has big support for big power depending on how much you spend. 200-900hp VR6 motor - same as above, but heavier. Many people turbo these for up to 4 digit numbers. As a bonus Porsche put these motors in the Cayenne so you can claim it's a Porsche motor if you get the right block. 20v turbo 5 - see 20v turbo 4. But more low end torque, more potential, and a longer engine. (Space becomes tight at this point) Something I'd like to do is a K20 with Honda trans. BIG turbo and all cheap Honda parts. Try for 500whp swap for less than 5k. I think if I tackle another car it's going to be either a really simple swap like Subaru 6 or Honda. Or a Audi V8 simply for the sound. I thought about the Honda engine and trans swap - the biggest drawback is the width you're dealing with running it transversely. I did some measuring while I worked at Honda and there'd be some interesting modifications to make it fit right and line up the axles. The V6 seemed too tall with it fit to the Honda 5 spd and to me it seemed like wayy too much work. But if someone put in the time to modify everything that was needed, you'd have a great weight setup and a sweet package because it's all designed to work together already. ECU and all... tempting for sure. |
Dave_Darling |
Nov 8 2018, 05:35 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I thought about the Honda engine and trans swap - the biggest drawback is the width you're dealing with running it transversely. The Honda V6 swaps mentioned above have used the stock 914 transmission, I believe. BTW, I am a firm believer that the 914 is an immense amount of fun with less than 100 HP; I take issue with the thought that "200 HP is where the fun starts". If you drive it right, you can have fun with two-digit power levels. Oh, and any time you're doing the first swap of motor X into a 914, you will want to measure and measure and measure and measure. Some engines that would seem to be natural for swaps (928 V8 engines, 944 engines, some others, even four-bangers) actually do not fit without some fairly significant mods. The firewall on the 914 tilts back at a noticeable angle, and that can cause fitment problems for taller engines. The firewall can be moved, the whole drivetrain can be shifted aft in the car, and other things can be done, but you will definitely want to figure out if any of those are needed first. --DD |
Lo-Fi Version | Time is now: 20th May 2024 - 10:02 AM |
